Author Topic: Twin Grasshoppers  (Read 7982 times)
Offline Chipmaster
Re: Twin Grasshoppers
« Reply #15 on: January 19, 2023, 12:11:13 PM »
Some more work on the engine - fabricated Vertical Links - like a ladder.
The silver soldering caused some slight distortion but being brass it was easy to straighten them.
 Twin Grasshopper Beam Engine by Andy, on Flickr
Silver soldered.
Cleaned up and hanging on the end of the beam.
Two
The first pair of Vertical Link Bearings machined from 5/16" thick brass plate. Not bolted to the base until I can see how all the components line up.
Milled out of 5/16 brass plate
Then the piston rod ends, brass, 1/4" BSF thread, rounded by file and linisher.
I'm also building a Baby Rider Ericsson 1/8 scale at the moment.
<a href="https://www.youtube.com/watch?v=G-zkn9z6aZo" target="_blank">http://www.youtube.com/watch?v=G-zkn9z6aZo</a>
Andy
« Reply #16 on: January 19, 2023, 12:34:38 PM »
You certainly are keeping yourself busy - both projects looks good  :ThumbsUp:
Per             :cheers:
Offline vtsteam
« Reply #17 on: January 19, 2023, 01:23:54 PM »
Great photos and a good looking engine!  :ThumbsUp: :ThumbsUp: :popcorn: :popcorn:
Offline simplyloco
« Reply #18 on: January 19, 2023, 01:30:26 PM »
Excellent. I like the ladder frames. Neat soldering.
« Reply #19 on: January 19, 2023, 03:37:26 PM »
Its all rapidly coming together  8)
That's a little  :o Ericsson. Good luck with getting it running  :) .
Online Dave Otto
« Reply #20 on: January 19, 2023, 09:36:29 PM »
Well the little Rider is sure cute! Nice work on the steam engines as well.
Offline Chipmaster
« Reply #21 on: January 26, 2023, 08:57:15 PM »
Thanks for your comments Dave, Jo, John, Per and VT Steam  :ThumbsUp:.
Very cold in my garage last week but I started work on the two connecting rods by sawing off two lengths of 35mm bar, the old Kennedy Hexacut hacksaw is excellent.
I have a portable propane gas heater that I move to where I'm working which makes it tolerable out there.
Machined down to 1" to fit in a square E40 collet block. (Flickr video)
Making lots of swarf, one of a few bucketfuls, probably consumed several kilowatts as well.
Drilled and threaded for the two big end bolts then parted off.
In the milling machine to square off the big end.
Then the other little end.
Back in the lathe between centres to reduce the diameter before taper turning for a fish bellied shape.
Before and after.
Both con rods machined to the same stage.
Machining 1.1/2" brass bar in preparation for the big end bearings, showering brass all around. (Flickr video)
I visited the local non ferrous scrap dealer this morning and was paid £4.00 per kilo for mixed brass and copper including swarf which seemed ok. It's an annual weigh in for me, how are scrap prices elsewhere at the moment?
Andy
« Reply #22 on: January 26, 2023, 10:39:42 PM »
Nice looking conrods, Andy!  :popcorn: :popcorn:
Interesting question about the metal scrap recycling.  I'm not familiar with where to find someone who will take my swarf in the states!
« Reply #23 on: January 27, 2023, 11:32:05 AM »
Hello Andy,
there is currently €4.05 per kilogram for brass shavings.
For brass MS 58 it is slightly more. They even take brass cartridge cases for €5.11.
For whatever reason?
I like your connecting rods very much 👍
Offline Chipmaster
« Reply #24 on: January 27, 2023, 02:30:08 PM »
Hi Michael, that’s roughly 12% more than my local dealer.
Kim, living in a smaller country everything’s relatively compact, there are a few scrap metal dealers and scrapyards in my vicinity.
Not so long ago people were stealing and weighing in iron drain grids and manhole covers from our roads. Now the law requires all payments to be credited to bank accounts.
Andy
Offline Chipmaster
« Reply #25 on: January 29, 2023, 10:11:09 PM »
I used brass for the two big end bearings by parting off four equal lengths of 1.1/2" brass bar. I bevelled the edges to ensure the join would be obvious after soldering them together.
After cleaning up.
Carefully set up in a four jaw chuck then starting to bore the hole that will fit the 1/2" diameter crankpin.
After boring and reaming to 1/2" the bearing had to be turned down to 1/2" thick to fit between the crankshaft webs, the first side was machined.
Then the job was turned round in the four jaw chuck to machine the second side.
Trying the fit in between the crank webs.
The brass big end bearings attached to the two connecting rods.
A mandrel for holding the big end bearing for the last bit of machining.
Ready to machine away the cheeks down to match the thickness of the con rods.
The almost finished big end bearings in position.
The next stage was to separate the two halves by melting the solder.
Connecting rods mounted on the crankshaft.
I only had to scrape a little silver solder that had strayed onto the bearing surfaces and they are a good fit on the crankshaft.
The next step is to mill forks at the small ends of the con rods.
Andy
« Reply #26 on: January 29, 2023, 10:27:22 PM »
Interesting way to make the bearings from round bar like that.  And all done on the lathe?
Offline Chipmaster
« Reply #27 on: January 30, 2023, 11:52:15 AM »
Hi Kim, yes all done on the lathe. I reckoned the method should ensure the faces would be at right angles to the bores and it’s faster than my milling machine.
Andy
Offline Chipmaster
« Reply #28 on: January 30, 2023, 07:37:41 PM »
Thinking ahead I left a surplus of material on the conrod so that I could mill a 3/8" slot to form the forked small end of the conrod without the opening being squeezed by the milling vice.
Then the excess was sawn off and the open ends rounded.
So far so good - swinging to and fro. (Flickr video)
Time to try one out. (Flickr video)
Then assemble the twins together and turn it / them over, the parallel motion hasn't been made yet but that didn't seem to matter. (Flickr video)
There were a couple of clearance issues but overall it is better than I was expecting in that it all lined up.
At this stage the model has become almost too heavy, it'll be worse still by the time a suitable plinth and base have been added.
It was reassuring to see the engine moving with no serious issues. However, I'm undecided on which will be it's best side if any, hopefully a decent paint job will help.
Andy
Online Dave Otto
« Reply #29 on: January 30, 2023, 08:00:16 PM »
That's impressive Andy, nice work!
