More nice looking castings!Question: why can't the HP bore be done till its bolted up?
I realised that every hole drilled from there into a port has to be at a different angle to the previous one, which might prove to be problematical! Unless I have misread the drawing that is...
I think you have read the print correctly. However, there is no requirement that the landing positions in the ports need to be in a straight line. As long as they do not break out from the valve face or remain too close to the cylinder bore they can land in an arc shape.I made this engine some years ago, and I believe that is what I did.Gene
Connecting the portsI used some masking tape with pencil lines on to align the drill. Angles were 25,27,30 and 35. It was remarkably easy!Only five more to do...
