The construction of this engine is serializedin the model engineer starting 16th August 1985 and can be found on the web...I also have a set of these castings that I bought recently and have started on it by making the HP part first ...It will be interesting to watch this build in Technicolor rather than black and white?!!!Willy
That looks to be a fine set of castings I would probably have tried to bore the cylinder bore using the boring head in the mill although that wouldn't have helped your eyesight problems
I haven't used exactly that, but something very similar:SNIPThis stuff looks the same except that it is impregnated with graphite. I found it MUCH better to use than some other cheap twisted graphite yarn that I got from the local hardware store. This stuff stays together much better. I was even able to remove one of the strands from the braid (to make it a little smaller) and it still stayed together very well. I was impressed. Made it very easy to work with.Kim
