Very good Chris,on the large machine, the valve is not 100 percent tight in the middle position. I then hear a very faint noise.It is important that the machine goes to STOP.MichaelProst
I've often thought about how to build the cylinder block.I could remember how I once built a horizontal steam engine with piston valves. There was a blueprint for it at the time. The block is made of six parts. Two pieces of pipe, two connecting pieces with channel and two flange plates. Everything is soldered.Maybe it is an inspiration for you.Something needs to be changed. But the flange plate at the top would be possible and have a different shape at the bottom. With two holes for the columns.But you might already have your own plans.Michael
