Quote from: Mcgyver on August 11, 2022, 05:24:41 PMQuote from: crueby on August 01, 2022, 04:15:44 PM'Steamer' Dave very kindly gave me a copy of the set of plans he has of the engine from this ship. Where do these drawings come from? I doubt I'll tackle this project, but Chris, I share your enthusiasm for just getting to pour over the drawings. They'd have to be out of copyright at this point....if they only exist in they physical form, I'd happy to volunteer to produce large format high res PDF's and make them available; I'd just like to see them.They came from a big old book he has, most of its missing but for the plans. A friend of mine has a large format scanner, I'm going to be seeing him this weekend and will ask if he can scan my copy of the prints, if that's ok with Dave?
Propeller shafts with bolted couplings is far less of an integrity problem, as the forces are [generally] acting in a single direction. The crank pin engine couplings however are subject to two opposite reaction forces at each revolution
Quote from: derekwarner on August 12, 2022, 05:13:18 AMPropeller shafts with bolted couplings is far less of an integrity problem, as the forces are [generally] acting in a single direction. The crank pin engine couplings however are subject to two opposite reaction forces at each revolutionI do not think that is correct. The applied rotational force (torque) from each cylinder varies from zero to maximum twice per revolution, but it does not reverse. If it reversed during each revolution the engine would be quite ineffective. Gene
Not only is it a Steam Engine where each Piston both Pushes and Pulls - but look at the Crank - 90 degrees Offset from Cylinder to Cylinder ...!!!...Minima - Yes - But no Zero Power part of the Rotation ....Where two Cylinders are approching the end of their Power-Stroke - the other two are taking over.In that sense, it is actually not different from a two cylinder Double Acting Steam Engine with a single 90 degree offset - that is why they are Self Starting (as there are no dead spots) I Do understand the problem with an IC Engine - about Opposite Forces - but besides bringine the Piston to a Complete Stop @ each end of the Stroke .... I honnestly do not know the actual forces involved in such a Steam Engine - newer seen an analyze .... but I expect it to change quite a bit with regards to the Timings of the Valves.Per
I spent a lot of time studying Liberty ship engines. Most of those had segmented crankshafts, and they did have large dowel pins as part of the couplings. Of course there are lots of other differences as well.Gene
Before getting the Ohio engine plans I had been looking at the Liberty Ship plans, that also looks like an interesting engine. Do you have any plans for one? I was able to find partial ones, but not enough to build from.
