That baring engine is 2m off the deck....you aint grabbin nutin honey!. Remote operation for sure. Probably lubricated from the next engine room deck above the main deck.
Catching up on the latest CAD work. This got slowed down for a while since I was going back and forth with their support team after the latest update broke a couple things. That seems to be worked out, which puts the fun back in.After doing more on the steam chest and valve slider, I decided to model in the pipes since that work had added the flanges they mount to. The pipes down the side act as the steam receiver chambers. Note that the IP cylinder sends its exhaust to both of the LP cylinders, and the exhaust from both LP cylinders collect up to one pipe on the way to the condenser. It really covers a LOT of details on the side of the engine:Which makes the other side of the engine much more interesting:And yes, the two LP cylinders have not been drawn yet, just the common parts from the IP are there and will be adjusted to fit the slightly larger LP diameters. For now, they are still in Transparent Cast Iron alloy!
Might be an idea to buy a 1932 Brown and Sharpe cam drive screw and nut machine Chris, for all those 'dots'! We had some such 1930's screw machines at one firm I worked for that would make a brass #2-56 x 1/4" hex head screw about every 10 seconds. They may have all been scrapped by now, definitely ancient tech, but they could sure crank out the hardware!
One more subsystem drawn up, the reverse engine and its links. This is a single-cylinder engine (red, next to and below the blue IP cylinder) with a second cylinder to dampen the speed of the movement. Its up/down stroke is connected to the long rod (yellow) along the length of the main engine, driving crank arms linked to each reversing link on each cylinder.One more subsystem to go, the turning/barring engine that will go on the end of the crankshaft next to the HP cylinder (left in the picture).
