Just piles and piles 'o parts, Chris! Can't wait to see them all come together on this bad boy! Kim
Your day at the RC pond sounds eventful! Glad everyone recovered their vessels OK. Latest parts looks great! Did the other shop elves dig out Boring Bar Bernie from the pile of solid gold blocks yet?
This morning the eccentric arms were trimmed to length and drilled/threaded on each end. Here is the stack of parts ready for silver soldering at each end of the arm. After that will assemble a set and double-check the length on the links that go between the center posts and the crank arms before trimming those rods to length.
Quote from: crueby on June 06, 2023, 03:55:52 PMThis morning the eccentric arms were trimmed to length and drilled/threaded on each end. Here is the stack of parts ready for silver soldering at each end of the arm. After that will assemble a set and double-check the length on the links that go between the center posts and the crank arms before trimming those rods to length.Nice stack of wishbones there! What are you going to wish for? Kim
