Author Topic: Handed Stuart Triple  (Read 2928 times)
Offline Steamingandy
« on: July 08, 2022, 08:07:55 PM »
Slightly different Stuart Triple this time, it’s will have a bronze base cast from a 3D print (not by me) the rest of the castings are an eBay set that has had the cylinder block started, but I will need to rework it to change the inlet/outlets over.
The crankshaft is one I made earlier from stainless I will also use stainless for all the steel bar stock, well that’s the plan.
« Last Edit: July 08, 2022, 08:40:10 PM by Steamingandy »
Online Roger B
Re: Handed Stuart Triple
« Reply #1 on: July 08, 2022, 08:36:49 PM »
Looks fun  :)  :ThumbsUp:  :wine1:
« Reply #2 on: July 08, 2022, 09:05:41 PM »
The machine base looks interesting!
I wish you good luck.
« Reply #3 on: July 22, 2022, 07:17:11 PM »
This is the process I use to manufacture the connecting rods hopefully the pictures tell the story
« Reply #4 on: July 22, 2022, 07:20:42 PM »
And the rest
« Reply #5 on: July 23, 2022, 12:48:27 AM »
That's a really interesting sequence of operations there!  I haven't seen it done that way before.
I really like the little brass end support you made to bolt between the fork for turning the reset of the connecting rod.  Very ingenious!
Online Roger B
« Reply #6 on: July 25, 2022, 10:00:23 AM »
A well planned manufacture  :) :ThumbsUp: The conrod remains in the same chuck until the final cut off?
Offline Chipswitheverything
« Reply #7 on: July 25, 2022, 10:13:43 AM »
Thanks for detailing this in your excellent series of photos.  I'll bookmark the procedure for when I may do some rods for my triple!   Dave
« Reply #8 on: July 25, 2022, 07:48:22 PM »
Yes it does, by having a centre between the forks pulling straight out of the Chuck holding against a centre and re tightening it stay true.
« Reply #9 on: July 25, 2022, 08:42:27 PM »
Just remembered don’t throw the end pice of material it’s perfect for machining the out of the big ends
« Reply #10 on: August 16, 2022, 04:36:25 PM »
I have never seen a solution for supplying oil to the big ends, so I decided to try this a 1.6mm hole through the rod with a countersunk hole at the top under the cross head, it will either work or fling oil over the cross head, we will see.
« Reply #11 on: August 31, 2022, 02:44:43 PM »
A little more progress on the handed Stuart triple, the first machining of a newly cast bronze base, it will certainly stand out from the standard engines, the pictures show the process steps.
« Reply #12 on: August 31, 2022, 03:01:35 PM »
Coming along great!   :popcorn:
« Reply #13 on: August 31, 2022, 07:25:42 PM »
Looks like a Very Nice Casting and as there was no complaints - I guess that it is a good Material to work on  :whoohoo:
I can relate to the sequence you use - by first milling the bottom flat, to get a reference - and then continue from there  :cheers:
« Reply #14 on: August 31, 2022, 07:48:07 PM »
One of the most frustrating things about the Stuart drawings for me is the lack of any datum’s, and the fractions
