You will probably have to make them out of round bar stock .Jo
Quote from: Jo on June 08, 2022, 02:36:22 PMYou will probably have to make them out of round bar stock .JoNot sure how practical or affordable it would be to slice up 70mm diameter round bar, most of the bar would go to waste.Still need to find someone who can supply it in the smallish quantities I need.Mike
Quote from: Vixen on June 08, 2022, 02:47:13 PMQuote from: Jo on June 08, 2022, 02:36:22 PMYou will probably have to make them out of round bar stock .JoNot sure how practical or affordable it would be to slice up 70mm diameter round bar, most of the bar would go to waste.Still need to find someone who can supply it in the smallish quantities I need.MikeTry cutting it the other way round Along the bar not across it. Your diameter needs to be the width of the big end.Jo
How wide are your conrods? I have some 150 d x 38 thick waterjet drops , i believe are 7075.Bill
Tried Smith's? smithsmetals.co.uk
https://wilmsmetall.de/?page=bin/productview&data=MjY4ITI3Mw==#[/size][/size]6x100x400 nearly EUR 27[/size][/size]I know, it is not in the U.K.[/size]
