Author Topic: High Pressure Steam Table Engine  (Read 25918 times)
Re: High Pressure Steam Table Engine
« Reply #165 on: September 20, 2022, 03:51:34 PM »
That was a Cheeky way of 'making them long enough' .... I would have worried that I also had 'glued the gauge' together with the bushings ....
Great to see progress again Jo  :cheers:
« Reply #166 on: September 20, 2022, 04:49:23 PM »
Thank you Per  :)
To finish off for today I did a bit more boring:
As I got close it was not good enough to measure with a Vernier so out came the telescoping gauges and the micrometre:
And finally the plug gauge fits
Having checked the fit of the bearings both in the stands and around the crankshaft it can go together:
The gap on the base is not wide enough for the bearing stand  :Doh:
Enough for today, other things are calling me  :mischief: How did I ever get enough time to go to work  :headscratch:
« Last Edit: July 27, 2023, 03:44:54 PM by Jo »
« Reply #167 on: September 20, 2022, 06:27:57 PM »
Thanks for the lessons in fabricating split bearings...I'd not seen that before.  :popcorn:
« Reply #168 on: September 20, 2022, 07:08:55 PM »
So many little unique features  :)  :)  :wine1:
« Reply #169 on: September 20, 2022, 07:27:26 PM »
now I see my mistake.
The upper part of the bearing has so much oversize that the cast attachment for the oil cup still comes out.
A nice job.
« Reply #170 on: September 22, 2022, 04:24:12 PM »
Thanks Guys  :)
The crank comes as a casting:
The first thing is to mount it up in a three jaw and get it mounted parallel - remembering that the circular bosses are actually tapered so we need to check against something parallel:
Then we can face the central boss:
And as expected the little dimple in the centre of the boss was not central  :ShakeHead: We need to drill deep to make sure our subsequent drilling follows the centre and not that dimple:
Having drilled and reamed it to size it can now be mounted on the hole on an expanding mandrel and the bottom faces both machined flat:
Now we can take the mounting mandrel and casting over to the milling machine, having clamped it square, find the centre of the hole with an edge finder:
Then use a pointer to move up to the correct throw distance then tap the casting to centre it on the little end:
Now it can be drilled and reamed:
We have the holes:
Now we can take the two bosses to distance:
You can see the hole drilled from the rear came out in the centre of the big end boss from this shot while the crank was rotating on the mandrel:
Mounted onto the crankshaft we find:
It hits the side of the hole in the bottom casting  :wallbang:
« Last Edit: July 27, 2023, 03:45:24 PM by Jo »
Offline Charles Lamont
« Reply #171 on: September 22, 2022, 04:58:50 PM »
Jo - I think you will find it goes the other way round.
« Reply #172 on: September 22, 2022, 05:05:45 PM »
Indeed as the conrod will otherwise hit the crankshaft end as it is in the photo
« Reply #173 on: September 22, 2022, 05:42:01 PM »
« Last Edit: July 27, 2023, 03:45:41 PM by Jo »
« Reply #174 on: September 22, 2022, 07:31:40 PM »
Nice and very instructional post as usual Jo  :ThumbsUp:
And the little 180 wrong placement is another thing most off us can relate to (one way or another)  :-X
« Reply #175 on: September 22, 2022, 08:11:42 PM »
Oh good someone is actually watching the build  :LittleDevil:
« Reply #176 on: September 22, 2022, 08:44:13 PM »
It will be interesting to see where the crank pin falls when it is the right way round, looking at the drawings even if fitted as in your photo it should have had 3/32" clearance.
Though the way the ctr line of the pedestal is dimensioned off the side of the cutout is not a good way to do it. Would have been better dimensioned from the engine ctr line or at least how far offset from the column ctrs
« Reply #177 on: September 23, 2022, 02:10:27 AM »
Hi "JO" , just catching up with this build ....looking good and some of those castings look really lovely and well detailed . An interesting engine and will be interesting to seeing it in motion...
"W" :ThumbsUp: :popcorn:
« Reply #178 on: September 23, 2022, 05:03:03 PM »
Good to see progress Jo!
« Reply #179 on: November 29, 2022, 11:49:31 AM »
Having had a joyful holiday from the workshop it is time to make some swarf again  :whoohoo: :
The flywheel was turned on Big C by first holding it on the outside of the jaws of the chuck:
Not forgetting to turn the back surface:
Before using coordinated turning to shape the curved outside surface and boring the centre so everything runs true  :)
To enable me to trim up the inside edge of the flywheel I chose to mount it on a face plate:
Flywheel in place:
And then it was time to take it all apart again:
So I could start looking at the yoke:
And yes another wrong measurement  :ShakeHead: the space between the two outside holes needs to be the same as the two slots in the engines table.
To start this piece I have drilled the three holes into the piece of steel I intend on using to make this part:
I will then find a piece of scrapbinium and use these holes to secure the yoke to the scrapbinium jig while I machining it
« Last Edit: July 27, 2023, 03:46:09 PM by Jo »
