Author Topic: Little Otto  (Read 8620 times)
Offline Alyn Foundry
Re: Little Otto
« Reply #30 on: June 26, 2022, 04:18:05 PM »
It seems we were posting together Jason, I look forward to seeing the latest from the Blacksmiths department….
I decided to try a needle roller bearing in place of the flanged Oilite bush the friction reduction is tremendous. From this….
<a href="https://www.youtube.com/watch?v=tTp7JS2FoXw" target="_blank">http://www.youtube.com/watch?v=tTp7JS2FoXw</a>
To this….
<a href="https://www.youtube.com/watch?v=JKr8j_PdxOQ" target="_blank">http://www.youtube.com/watch?v=JKr8j_PdxOQ</a>
The new bearing does nothing for the high precision machined flywheel so a new, replacement crankshaft will have to be made to accommodate some “ proper “ ball races.
 :cheers: Graham.
Offline Zephyrin
  • near Paris, France
Re: Little Otto
« Reply #31 on: June 27, 2022, 08:33:30 AM »
great improvements, your engine is now a runner...
I wonder why do you are using such a sooty flame and not a hotter one ?
Re: Little Otto
« Reply #32 on: June 27, 2022, 01:24:09 PM »
Hi Zephyrin.
Yes we’re definitely getting there. I have always found that the “ dirty “ flame seems to work for this type of engine really well, particularly on just finished engines.
Otto’s patent shows an automated flame delivery system that should mix the gas and air more effectively and, hopefully make a much cleaner burn.
 :cheers: Graham.
Re: Little Otto
« Reply #33 on: June 27, 2022, 08:33:05 PM »
A cast iron disc is supplied for the cylinder head or end cover - not sure what to class it as. No chucking piece on this but not a problem, after cleaning off a few bits of flash with the linisher it was held in the soft jaws, faced, OD turned and then a spigot formed to locate into the cylinder bore. After that it was just flipped over and the other side faced off but left over thickness for now.
I took a few clean up cuts off the inlet and exhaust blocks to get an idea of their final size and juggled them about on the engine to see what was the optimum position.
Once happy with the positions the some measurements were taken and then added to the CAD model. This was then used to complete the machining. From the underside there is a slot that lines up with the cast in slot of the inlet block that has had a chamfer milled on the inner edge to aid flame flow. The large circular hole is the exhaust, I wanted to get this as large as possible so have overlapped the flange but there is still plenty of metal around it to get a good seal. There are four 3mm holes to mount the inlet Block two counterbored and two others countersunk as the metal above the flange would be too thin to counterbore. Finally five 3.5mm holes for the studs to hold the part to the cylinder, the the right two will also hold the exhaust block.
After drilling the two stud holes in the exhaust block these were used to set it level in the mill vice so that the exhuast pipe boss could be drilled and tapped, as I'm making my engine to metric sizes I opted for M10 x 1.
This thread was then used to hold the casting in the lathe so the boss could be turned round and then blended into the main shape by hand.
My mill has no problem doing circular recesses so I cut a 20mm dia x 11mm deep one first then a 10mm x 1mm deep one in the bottom of that. The 20mm dia will locate the exhaust valve disc and the smaller one the spring. I then needed a way to allow the exhaust gasses past the disc so milled four pockets just leaving a small sections of the 20mm dia remaining.
Quick check with a  piece of 20mm bar and it just fits nicely
Re: Little Otto
« Reply #34 on: June 28, 2022, 12:17:17 PM »
As mentioned in other places, I really liked the way you provided the exhaust valve guide Jason.   :ThumbsUp:
We definitely have different ways and ideas of how to make this engine. I opted for rather small, for me, stainless Steel 2 mm studding to hold down the valve block to the cylinder head. And also used 2 mm Brass grub screws as a guide for the exhaust valve disc.
I used a tee slot cutter to create the slide ways and more 2 mm Brass grub screws to provide adjustment. The photo says it all….
 :cheers: Graham.
Re: Little Otto
« Reply #35 on: June 28, 2022, 01:20:46 PM »
I must add that my engine was rather hurriedly done with a view to it joining its big brother over in Holland earlier this month. I went for as many “ off the shelf “ components that I could to save on machining and fitting time. I used 4 mm Rose joints for the conrod and Oilite bushes for the mains. This has now proved to be a problem insofar as the conrod is really noisy and the bushes are really heavy on friction.
<a href="https://www.youtube.com/watch?v=E_c4y1kNEsM" target="_blank">http://www.youtube.com/watch?v=E_c4y1kNEsM</a>
 :cheers: Graham.
« Last Edit: June 28, 2022, 01:23:50 PM by Alyn Foundry »
Re: Little Otto
« Reply #36 on: June 28, 2022, 06:27:40 PM »
Today it’s hard to imagine that these engines were in common use driving small loads and were built in reasonable quantities. Here in the UK a patent was granted to a Mr R M Lowne in 1892 for one such engine. He manufactured is own versions, a picture of a twin is shown below. Another firm, Hardy and Padmore, also made a vertical version under license.
What’s interesting to note is that they both used Brass pistons. So armed with this knowledge I decided to try out a different approach with Little Otto. I have had quite a bit of experience with metal spinning over the years making spares for Tilley lamps. There’s virtually no waste involved with the production and the finished product requires very little work to complete. A Steel “ chuck “ was turned up with the ubiquitous 1” Whitworth thread made to fit the spindle nose of the spinning lathe. Discs of 2 mm thickness “ cartridge Brass “ were then placed upon the chuck and spun down to form a cup. The first attempt saw a taper of over 2 mm from crown to skirt, absolutely useless…. The chuck was gently tapered down from the crown to the skirt end, the cups were then re annealed and the metal sprang back to under the permitted maximum diameter.
The Brass piston spinning was then placed upon a suitable mandrel and the OD machined parallel to suit the cylinder bore. A single stainless Steel counter sunk Allen cap screw was used to fix the piston to the small end yoke.
Photo 1. The chuck.
Photo 2. Lowne twin cylinder.
Photo 3. Hardy Padmore engine.
Re: Little Otto
« Reply #37 on: June 28, 2022, 06:46:31 PM »
interesting little engines.
As Grahams piston is now in the engine here is mine as it came off the spinning lathe, just a few thou of taper due to spring back, it's a fine line between getting a parallel side and not being able to remove the spinning from the former, no doubt mass produced items have the time to do a few more test ones to reduce the taper to a minimum.
Was it 2mm sheet or 1.5 as that is about what the flat part of mine measures, bit thicker around the edge as you would expect.
Re: Little Otto
« Reply #38 on: June 28, 2022, 08:33:31 PM »
Jason and Graham, I’m enjoying watching these builds and the two different approaches you are taking in this fascinating engine.
Re: Little Otto
« Reply #39 on: August 01, 2022, 07:37:54 PM »
Must be time fore a bit more progress.
During one of our many e-mails Graham had mentioned a forged crankshaft although in the end he did not use one going for a two piece crankshaft in the end to aid assembly with the scotch yoke. However I decided to give it a go and Forged mine though not in the sense Graham was originally thinking of.
Starting with some bar that had been machined down to 10mm x 12mm section some holes were drilled and reamed for 8mm PGMS shafts.
Then a bit of turning between the two holes taking the rectangle down to 10mm dia with a 2mm nose diameter grooving tool so a 1mm radius was left at the ends.
Some rounding over of the ends on the rotary table was next no pictures of that as Jo may not approve ;) Before silver soldering it together as you would a normal built up crankshaft.
Some more rounding on the Rotary table saw the basic "forged" parts of the crankshaft start to take shape, I'll sneak in a picture this time.
The remaining shaping was done by filing which then just left milling a keyway to complete the crankshaft
A quick spray of primer is always a good way to see if there are any bits that need a bit more attention with the file, then a final coat.
Graham had some pistons spun from soft brass sheet as shown here
There was a slight taper to the sides due to spring back of the brass despite the former having a negative taper but it's a fine line between parallel sides and not being able to get the spinning off the former. To true up the sides I turned a short spigot on the end of a stub of aluminium to a firm fit inside the piston and added support from the tailstock via a pressure pad so the OD could be skimmed down to fit into the cylinder.
The cylinder was then honed to remove a very slight taper until the piston slid freely in and out.
I also did some more work on the inlet side of things with a shutter made from 3/32" gauge plate and two "L" shaped gibs to guide it. The two levers that convert the movement of the cam to movement of the shutter via the pivot were also made from 1.5mm sheet with bosses soldered on.
With enough bits now made it was time to have a listen to Otto's first words. Sounds like it should work even if it's just for duck hunting!
<a href="https://www.youtube.com/watch?v=DePiCL5zCus" target="_blank">http://www.youtube.com/watch?v=DePiCL5zCus</a>
Re: Little Otto
« Reply #40 on: August 01, 2022, 07:43:32 PM »
That's some interesting takes  :ThumbsUp:  :ThumbsUp:  I like the faux forged  crankshaft  :)  :)
Re: Little Otto
« Reply #41 on: August 02, 2022, 11:46:43 AM »
Blimey, this thread got buried quickly overnight.  :)
Some great workmanship again Jason, puts mine to shame. I don’t have much to report as the family was hit by the dreaded Rona a couple weeks ago. For me the fatigue was so bad that I’ve just been sleeping for the most part.
What has become very apparent is that friction in the main bearings will need to be as low as possible. As mentioned, my crankshaft was made from 8 mm Silver Steel with 10 mm webs. I made it so the crankpin was a sliding fit into the other web. This allowed me to minimise the machine work on the Scotch yoke ( a simple 8 mm slot milled from end to end ) however the addition of the second half of the crankshaft will stall the engine.
I don’t have the same, excellent, piston to bore fit as you do because I didn’t have the two components available at the time of boring the cylinder. This meant that when the piston returned from the Spinners after the chuck modifications it was already fitting the cylinder by around half the length. After truing just a third of the skirt fits with any seal. This might have a bearing on why mine isn’t very powerful? As your build progresses we will ultimately find out!
<a href="https://www.youtube.com/watch?v=XTcbIEOrg_E" target="_blank">http://www.youtube.com/watch?v=XTcbIEOrg_E</a>
 :cheers: Graham.
« Last Edit: August 02, 2022, 12:04:22 PM by Alyn Foundry »
Re: Little Otto
« Reply #42 on: August 02, 2022, 07:07:57 PM »
I like your last part Jason - great fit (and Sound)  :ThumbsUp:
Very impressed with how well you got that Flame dialed in Graham  :praise2: Both the very blue flame during induction and the Pilot Light in between.
Love to see both builds here  :cheers:
Re: Little Otto
« Reply #43 on: August 03, 2022, 11:44:14 AM »
Thanks for the interest Per.  :ThumbsUp:
It has taken quite a lot of time to get to this point. Much experimentation with hole sizes for the gas were tried. Initially two 0.5 mm were drilled through the 4 mm thickness gauge plate and the casting had a couple of 2 mm section Viton O rings to help seal the joint. It was hoped that the gas would hit the roof of the, now nicknamed, “ Snail house “ and travel, after being ignited into the flame port. Needless to say it didn’t work at all to plan! In the end 2 pieces of 1/8” OD Copper tube were bent, cut and Silver soldered into the shutter.
I discovered that the little O rings were causing severe drag on the shutter and once removed it began to run. Having much larger holes for the gas enabled me to run at a greatly reduced pressure ensuring little to no leakage between the two, highly polished surfaces.
What has now become apparent is that as the slide moves to open the fuel to the flame port the pilot flame virtually extinguishes. You need a pilot for the pilot.  ;D  I have got some little Brass taps on order so that the branch between the ignition and fuel supply can be separated so the pressure drop won’t affect the pilot light.
 :cheers: Graham
Re: Little Otto
« Reply #44 on: August 03, 2022, 08:11:03 PM »
     :Lol:
I can't say that it surprises me much about the plans - Mice and Men - springs to Mind  ;D
But like my suprice on how well you got it dialed in (for such a small scale) - I'm also glad to see that you succeded - this requires some Patience and Persistance :ThumbsUp:
