Author Topic: DRO for Samantha Bell!  (Read 9587 times)
Re: DRO for Samantha Bell!
« Reply #60 on: June 21, 2022, 12:59:06 AM »
I wish Chris!   I've looked under the machines and the bench     Not seeing it!!!!
It up and tight, and .003 over 35 or so inches is about as good as I can get....so I'm calling that....now to the readhead.....but first I rest my leg....major leg cramp!!!!    Not good with 30 feet of Orthopedic wire holding my patella tendon together!    Hurts!
« Reply #61 on: June 21, 2022, 01:37:05 AM »
Spec is 0.1mm /meter...or about .004/40"....so I'm not done yet.....I'll keep tweeking it ...it's going to take a while....
Offline propforward
  • MN, USA
« Reply #62 on: June 21, 2022, 01:14:58 PM »
Yeah - it's a process. You're doing great though - it will be well worth it.
Forging ahead regardless.
« Reply #63 on: June 21, 2022, 03:25:29 PM »
Check the attic and the dog house - you may have some BIG shop gnomes!   :ROFL:
« Reply #64 on: July 13, 2022, 01:22:43 AM »
Some progress made this weekend, I am working on the X axis now, ....to get the cross slide off, I had to take the saddle off.   Seems I made the new tool wall 1/4 inch too close to the lathe to move the cross slide off the saddle in the normal way.   No worries, it comes off with 4 screws...
Pictures to come
« Reply #65 on: July 18, 2022, 03:26:46 AM »
Making some progress on the DRO.... had to take the saddle off to get the cross slide off....
Got the Z and X mag scales mounted....nearly....
Offline propforward
  • MN, USA
« Reply #66 on: July 18, 2022, 01:29:59 PM »
Looking good Dave - nearly there!
« Reply #67 on: August 14, 2022, 09:30:58 PM »
Got a little time in the shop today.....I have Samantha Bell torn down at the moment, so I decided that as long as I have the hood up, Id take some measurements......Everything is exactly where I left it 10 years ago.....I'm going to touch NOTHING....and just put the scales back on...which is good as I'll need her next week.   I'm going to get vacation and some time working on my boat!.... :whoohoo:
It's nice to just see a few polish marks on the saddle bearing surfaces with all my frost still in place.     :cartwheel: :DrinkPint:
« Reply #68 on: August 14, 2022, 09:39:43 PM »
 :pinkelephant:
« Reply #69 on: August 14, 2022, 10:52:32 PM »
Do understand why you are happy that ALL your hard work back then - is still up to the same specs  :praise2:
It speaks Volumes about the quality of your work and how well you treat your Tools  :praise2:   :praise2:
oh - and Enjoy a well earned Holliday  :whoohoo:
« Reply #70 on: August 15, 2022, 12:50:40 AM »
I did find that the apron is kinda dry...like it's not getting enough lube.   I'll investigate....
« Reply #71 on: August 22, 2022, 11:47:08 PM »
I've gone back and forth dithering as to scale orientation with the cross slide.    Enough   Pick one and go!
That said I'll be putting it in like the following photo's show.   The challenge is getting to the compound lock screw and the gib screws after install.....that said, I have found putting the square head set screws for the compound back in will solve the compound lock problem.   For the gib screws, I've changed the screws over to hex head cap screws which I'll trim to a close length and be able to get to them from the top or the bottom of the scale.    I may need to make a tweek here and there, but lets get this thing together!!!
So tomorrow I'll get the Z buttoned up, and maybe get the DRO box mounted.   Then tackle the rest of the X.
« Reply #72 on: August 24, 2022, 12:44:29 AM »
X AXIS IS IN!  :whoohoo:
« Reply #73 on: August 24, 2022, 11:44:19 AM »
Looks really good Dave  :ThumbsUp:
I hope it will work well for you  :cheers:
« Reply #74 on: August 24, 2022, 11:55:30 AM »
 :ThumbsUp:  :ThumbsUp: :ThumbsUp:
