Hi All !
Sharing some of my diesel discoveries:
1/ Injection time: More precisely the time the lobe begins to contact the pump piston: 22 to 45 degrees before TDC
2/ Engine runaway : Should be worried?
If your design calculates lobe timing, intake and exhaust ports....exactly like a full size diesel engine then you should worry. But with a small engine you can easily stop the engine.
With many tests, my engine can not runaway
3/ Injection : Fuel vaporization-Atomized fuel . How to inject fuel
3A/ Fuel vaporization-Atomized fuel : It is necessary but not all.
Fuel vaporization-Atomized fuel will give you an objective view of the efficiency of the pump and injectors: the pressure generated by the pump, the tightness of the injectors....and when the engine is running it will have very little smoke.
" Not all " because when i make some test with my engine the injectors just "inject " fuel - as in the picture (Some cases are even worse)- -and the engine is still run
This leads to 2 cases: a/ the engine runs but a lot of smoke and some unburnt fuel (it looks like mud) comes out the exhaust pipe and b/ the engine a lot of smoke . Solve this problem: simply increase the compression force of the needle spring
3B/ How to inject fuel :
fuel injection : radiates from the center - good
Fuel injection is left or right: it doesn't matter
With a full size diesel engine, the fuel vaporization-Atomized fuel, the fuel injection, ... needs to be really good because it concerns the performance ... of the engine, and that's what is really needed.
But with a homemade diesel engine, you can stick to that rule if you want, and that's how I do it with my engine.
If you only need one engine running then it shouldn't be too important. And the engine has running, you can easily adjust the injectors...to make the engine run better
One important thing is : the injector must be completely sealed .
If the injector is not completely sealed it will affect the pressure in the cylinder and the oil pressure in the oil pipe
Hope this gives those who are or intend to build diesel a little more confident
