Author Topic: 1/4 " spark plug copper washers  (Read 4212 times)
Online Vixen
« on: May 11, 2022, 03:24:19 PM »
I don't know about you, but I am forever losing the tiny copper washers for my 1/4" spark plugs. One moment they are there on the workbench, the next moment they are gone.... lost forever. I blame the shop elves.  :ShakeHead:
Do you know of a reliable and affordable source of affordable 1/4" copper washers in the UK? I have found some 0.265 x 0.375 x 20g washers but they may be a bit too loose on the 1/4 spark plugs. Has anyone tried these?
Offline Dan Rowe
  • Dripping Springs TX USA
Re: 1/4 " spark plug copper washers
« Reply #1 on: May 11, 2022, 04:14:24 PM »
Mike copper is crazy  :Director: expensive. Here is what I found from China:
https://www.ebay.com/itm/133697769158?hash=item1f21020ec6:g:Bz8AAOSw-HlgU3l-
Do you have a better source than that?
Cheers Dan
ShaylocoDan
Offline Quadra
  • Cambridge UK
« Reply #2 on: May 11, 2022, 04:24:33 PM »
Hi Vixen
Try Minimag for 1/4 copper washers.
Offline wirralcnc
« Reply #3 on: May 11, 2022, 04:38:12 PM »
Can you not make them if you had some copper?
Offline Dan Rowe
« Reply #4 on: May 11, 2022, 04:44:48 PM »
Yes but it takes time to make a tool and copper sheet is still crazy expensive so factor in the time to make them and I do not really see any cost savings to the old pocketbook.
The only advantage is that the maker will have very good size control so that might be the deciding factor in the equation.
Cheers Dan
« Last Edit: May 11, 2022, 05:34:27 PM by Dan Rowe »
ShaylocoDan
Offline wirralcnc
« Reply #5 on: May 11, 2022, 04:47:58 PM »
We have to make copper washers all the time in work.
Some times 40 at a time. We make from round bar stock and part off. As you say perfect control of the sizes.
« Reply #6 on: May 11, 2022, 05:07:05 PM »
Do these look like what you need?
https://holzapfeldampf.ch/produkt/dichtungsscheiben-kupfer/
I can send a packet or two if they suit.
Offline Dan Rowe
« Reply #7 on: May 11, 2022, 05:30:54 PM »
I use red fiber washers for model boilers and they might be useful for spark plugs. I have no idea of the service life in that application but they are cheap and I get a chance to tell one of my favorite sea stories.
https://www.ebay.com/itm/403381767615?var=673413051921&hash=item5deb6d4dbf:g:qYcAAOSw87ZgSdTm
I was the first assistant engineer on one of the US Lines Econ class of ships with a 7-cylinder RLB Sulzer main engine. This was the first time I sailed first on a new class of ship and I was feeling a bit out of my depth. I know my way around a shop and I have a good memory of resources I spot that might come in handy.
The ship had been in a two-year layup and everything was stripped or stolen. No spare parts to speak of and almost all the tools had taken a hike. In the middle of the big pond all the air start valves had overheated and burnt the paint black. This is very bad as it would not be possible to restart the engine in this condition.  We checked the spare parts box and no copper gaskets were found inside it. The Chief Engineer asked me if I had ever heard of Klingerite being used for a head gasket. I said no but I could make them quick to give me time to make a proper gasket.
I had spotted a sheet of copper about the correct thickness but I knew there were no tin snips to be had. I had also seen a dozen carpenters' hatchets the kind with a straight blade and a hammer head on the other end. I threw the copper sheet on the steel workbench and used angle iron and the hatchets to cut out some copper blanks. Now over to the lathe which was a big industrial unit and I had no idea how to turn it on. With the blanks screwed to a board on the faceplate, I used the jog button for the on switch. I had a set of gaskets ready for shutdown and replacement in the morning.
The Klingerite gaskets held just fine and we replaced them with the copper ones and sailed happily on our way. Several years later in a bar in Boston harbor the chief reminded me of the story. Both the ship and my skills as a first were in question in his mind at the time. He said, "I was so relieved when you made those gaskets because I knew I had a first."
Well in conclusion will red fiber washers work? I have no idea but they are cheap and easy to replace. Your milage may vary.
Cheers Dan
ShaylocoDan
« Reply #8 on: May 11, 2022, 05:33:19 PM »
I had a quick look at what I have. The first picture is a Holzapfel 6 x 10 washer, the original washer and a Regner Dampfmaschine 6mm washer. I think that the Holzapfel 6 x 8 mm washer may be better but I don't have an example. The last picture is the 6x10 washer on a sparkplug.
Offline stevehuckss396
  • Sterling Heights, MI USA
« Reply #9 on: May 11, 2022, 05:39:13 PM »
Get some 5/16 or 8mm copper or brass , heavy wall tubing , and drill the center out to about .255 inches and them part them off. I make mine .040 inches thick. Brass is easier to machine and I have not had a problem with a poor seal.
« Reply #10 on: May 11, 2022, 09:43:29 PM »
Its a pain trying to find somewhere that makes the right size. I keep planning to make myself a press tool to make my own so they are the right size  ;)
I wonder how many of you out there remember to anneal your copper washers every time before you tighten on to them?  ::)
Offline Dan Rowe
« Reply #11 on: May 11, 2022, 09:55:46 PM »
Jo we used hundreds of them on the diesel engines. If you did not anneal them you would be redoing the job very soon. A good teaching system. Daihatsu generators have rocker arm cooling oil and HP fuel lines in the rocker box, if the rocker oil level started to go up it had a fuel leak. The quickest way to fix the problem was to change ALL the copper gaskets in all eight cylinders and do it your self with newly annealed gaskets. You might be able to guess why I know this.
 :cheers: Dan
ShaylocoDan
Online Vixen
« Reply #12 on: May 11, 2022, 09:59:40 PM »
Thanks guys and gal for all the good advice and so many options. The MEM forum never fails.
My Chinese 1/4 x 32 spark plugs actually measure 6.1mm OD, a bit short of the theoretical 6.35mm = 1/4". So with a little luck and a following wind, a 6mm copper washer may just fit. I guess a tight washer could be stretched (expanded) with a taper drift.
So what to do?
I have located some 8mm x 1mm wall copper tube. I will try parting that into thin washers and see how that goes. Failing that, I will try some of Roger's  Swiss 6 x 8 copper washers. Having a little difficulty with their website but I think the 6 x 8 x 0.5 copper washers are qty 20 for 6 CHF (about £5) plus some postage.
Thanks again, I will let you all know how I get on, as we all need extra spark plug washers (annealed) from time to time
Offline Dan Rowe
« Reply #13 on: May 11, 2022, 10:06:30 PM »
My Chinese 1/4 x 32 spark plugs actually measure 6.1mm OD, a bit short of the theoretical 6.35mm = 1/4". So with a little luck and a following wind, a 6mm copper washer may just fit. I guess a tight washer could be stretched (expanded) with a tapered drift.
Mike I would use a tapered reamer to fit the copper gaskets that are a tad off. I think that would be much simpler than an expansion drift.
Cheers Dan
ShaylocoDan
Online Vixen
« Reply #14 on: May 11, 2022, 10:21:04 PM »
Hello Dan,
Yes, I have a couple of taper reamers about that size, but they are no longer that sharp. I would have to reamer the raw tube before parting off as it would be near impossible to hold the tiny washer afterwards. Whereas the expansion drift tapped through the washer into a drilled hole, does not need the washer to be held. It's another one of those 'try it several ways until you find what works' situations.
