Author Topic: PM Research #3 Power Plant  (Read 1385 times)
Offline Krypto
« on: April 09, 2022, 05:30:45 PM »
Below is a picture and short video of my last project, a PM Research #3 Power Plant.
<a href="https://www.youtube.com/watch?v=RDTyfrQfr6Y" target="_blank">http://www.youtube.com/watch?v=RDTyfrQfr6Y</a>
It features a Jensen 2.5" electrically fired boiler providing steam for a PM Research #3 engine which turns a PM Research Dynamo powering a small incandescent light bulb.  I did all the machining for the engine, dynamo and pipework.  The boiler originally came from a Jensen 25 steam engine, but I have several of these and this particular one wasn't seeing much use.  It can be replaced to the donor engine at a later date if I wish.
Re: PM Research #3 Power Plant
« Reply #1 on: April 09, 2022, 06:40:02 PM »
Hi,
I like the facility.
A good combination of engine, boiler and dynamo. And with a real lightbulb!
Offline Krypto
« Reply #2 on: April 09, 2022, 09:20:08 PM »
Yes, I like the look of real light bulbs and they put a nice load on the engine.
Offline MJM460
« Reply #3 on: April 10, 2022, 03:03:14 AM »
Hi Krypto,
Welcome to the forum.  Nice work on the engine.  Do you have any progress photos?
Lovely to see a complete working power plant in action.
Have you made any attempt to measure the dynamo output voltage and current?  Along with the required boiler pressure?
Offline Krypto
« Reply #4 on: April 10, 2022, 02:38:19 PM »
Thank you!  I do have progress photos, but won't bother posting them here as I have yet to deduce how to post photos inline with text.   Also, with the high caliber of work posted daily on this site, I would imagine most viewers would be bored stiff viewing the construction of a simple model such as the PM #3.  However, if you look at the bottom of my posts, you can see a link to my blog which does have a few build articles on this power plant with photos to view if you wish.
Generally I steam this model at around 20 psi.  In the video, you can read the gauge at the top of the boiler if you have a big enough screen.  The PM dynamo will produce much more energy than I'm showing here, but this little engine could never drive it.  I have a selection of E10 bulbs so with the proper belt ratio I can pick one that will produce a pleasing light and yet not overwhelm the engine with an unworkable load.  Without looking, the bulb is probably a #131 which when nicely lit is around 1.30V and .10A.
Offline propforward
  • MN, USA
« Reply #5 on: April 10, 2022, 09:26:44 PM »
That's a great steam plant. I never tire of seeing model engines being built - there is a lot of enjoyment to be had from all of them. That PM number 3 is a delightful engine.
Forging ahead regardless.
