Author Topic: The Wolf Nr 1  (Read 8283 times)
Re: The Wolf Nr 1
« Reply #90 on: May 01, 2022, 04:50:00 PM »
For the valve to switch to filling or pumping, I once made it out of Teflon.
Re: The Wolf Nr 1
« Reply #91 on: May 01, 2022, 04:53:03 PM »
And here they are, side by side.
I wish everyone a happy first of May.
Re: The Wolf Nr 1
« Reply #92 on: May 01, 2022, 05:08:49 PM »
Looks great  :praise2:  :praise2: Is the bell to confirm to the engineer that the lubricator is working?
Re: The Wolf Nr 1
« Reply #93 on: May 01, 2022, 05:26:52 PM »
It's a real testament to your work that it can stand up to such close-up photos without a flaw or machine mark in sight, nor anything to give away the size. Beautiful detailing.
Offline Minh Thanh
Re: The Wolf Nr 1
« Reply #94 on: May 01, 2022, 05:37:17 PM »
it continues with the chassis. The wheels are screwed to the boiler at the rear and can be steered at the front.
The plate has a rotation limiter so that the front wheels do not hit the boiler.
Now you can push the machine through the room. 🙂
Need a little pony or two!
Greetings Michael
    The wooden wheel is so beautiful !!!  :ThumbsUp: :ThumbsUp:
Re: The Wolf Nr 1
« Reply #95 on: May 01, 2022, 05:39:17 PM »
Thanks Ron.
And Roger the bell only goes off when the piston hits the bottom. Then the outer bolt jumps up and when the upper hand lever passes the bolt again, it loosens because it is on a left-hand thread. The release activates a ratchet and strikes the bell.
Re: The Wolf Nr 1
« Reply #96 on: May 01, 2022, 05:50:53 PM »
At 2:50 you can see it in this video.
But hardly hear!
<a href="https://www.youtube.com/watch?v=3X2ekJgKSgM" target="_blank">http://www.youtube.com/watch?v=3X2ekJgKSgM</a>
Re: The Wolf Nr 1
« Reply #97 on: May 01, 2022, 07:55:53 PM »
Terrific video of a great machine, great that its still in running condition.   :ThumbsUp:
Re: The Wolf Nr 1
« Reply #98 on: May 01, 2022, 08:31:09 PM »
My goal was actually an operation under steam, but it is also possible with a little compressed air. The machine is in good condition. But the boiler is badly rusted. I like it that way too.
Re: The Wolf Nr 1
« Reply #99 on: May 01, 2022, 08:36:39 PM »
That was a great adventure.
<a href="https://www.youtube.com/watch?v=63FgQm88hPs" target="_blank">http://www.youtube.com/watch?v=63FgQm88hPs</a>
Re: The Wolf Nr 1
« Reply #100 on: May 01, 2022, 10:25:33 PM »
So have you both participated in completely restoring the original full sized version and build this marvelous model and documented it both in a German magazine + here on this site in English ...?
Re: The Wolf Nr 1
« Reply #101 on: May 02, 2022, 06:53:10 AM »
Yes, but both are now almost 10 years ago.
The large steam engine comes from the junkyard and used to be in a sawmill.
Re: The Wolf Nr 1
« Reply #102 on: May 02, 2022, 11:15:24 AM »
Still a very big amount of work, time and effort put into this  :praise2:   :praise2:
