Author Topic: 9x20 Lathe Belt  (Read 1089 times)
Offline Davyboy
  • Merrill, Wisconsin, USA
9x20 Lathe Belt
« on: March 15, 2022, 01:45:36 PM »
My HF 9x20 lathe likes to break the small belt at the worst possible time.  With no direct replacement locally available, I came up with a different source.  A trip to the local auto parts store yielded this. The length was a bit hard to match exactly.  Simply cut the belt, following the grooves molded into the belt. I only get 2 pieces to use, but it's 2 for about 6 bucks. They seem to hold up a lot better than the ones I get from flea bay.  Hoping this is helpful for someone.
Offline Hudmut
  • Jr. member
Re: 9x20 Lathe Belt
« Reply #1 on: March 15, 2022, 02:24:14 PM »
The correct name for stock factory belt is Gates Polly flex 5M (5mm wide). The bigger machines use a 7M (7mm wide) but if your like me a normal Z series belt works just fine in place of the 7M.
« Last Edit: March 15, 2022, 02:31:15 PM by Hudmut »
Offline Bruno Mueller
    • My Homepage
Re: 9x20 Lathe Belt
« Reply #2 on: March 24, 2023, 08:19:02 PM »
The correct size of the belt depends on the installed engine.
5M x 710 to 5M x 730 has already been installed in the machines.
The Emco Compakt 8 prototype machine had a 5M x 690 belt.
http://mueller-bruno.de/  http://www.bosch-combi.de/
Whoever talks shit about me behind my back is in the best position to lick my ass.
Greetings from the southwest of Germany.
Offline stevehuckss396
  • Sterling Heights, MI USA
Re: 9x20 Lathe Belt
« Reply #3 on: March 26, 2023, 12:32:58 AM »
My HF used a 5M710. The KBC takes a 5M730 but the previous owner changed the motor so I'm not 100% sure if that is what it used new.
