And sorry for muddying up your build....I'll go back in my hole....
That HP piston looks thicker than the LP one. Or is it that it is partially dismantled Jo
That is an interesting arrangement of the valves and porting. From what I can see, it looks as though the HP valve is inside admission and the LP outside, allowing short, direct transfer passages linked by a vertical communicating passage.
Chris, those steam driven Duplex pumps of the original vessel are interesting, so maybe a question for steamer Dan if I may.......A few assumptions......going from astern..The red pump....could this be an original pump as installed, and now used as a standby for seawater to condenser cooling?The blue pump ......a replacement for a worn out original red pump, and currently used as the seawater to condenser cooling?The green pump .....don't know...except to say the double head gasket on the pipe near the blue pump is of 3 bolt punched so must be for the green pump?All of the small bore pipework & assorted elbows & unions is pretty messy... typical....just get it piped up for now, will tidy it in the futureThe triangular wooden mountings are certainly substantial So, what is the function of the green pump? Derek
