Author Topic: Cup of Tea Engine  (Read 1383 times)
Offline Robert Hornby
  • Terrigal NSW Australia
Cup of Tea Engine
« on: February 18, 2022, 02:37:03 AM »
Some 25 or so years ago I made a cup of tea engine and subsequently sold it (that is another story). I wish to build another one but cannot find the original plans, so I am making it from memory. Please help with the ratio of displacer volume compared with power cylinder displaced volume, or is it not too important? By the displacer volume I mean the volume of the cylinder minus the volume of the displacer.
Robert
Offline Hugh Currin
  • Box Elder, SD, USA
    • www.currin.us
Re: Cup of Tea Engine
« Reply #1 on: February 18, 2022, 03:56:51 AM »
Robert:
I believe the displacer to power cylinder volume is dependent on the temperature differential being exploited. The Low Temp Differential engines have a large displacer compared to power volume.
I'd suggest you look at some of Jan Ridders designs . He may even have a design you could use directly. I've found him very responsive in sending drawings.
I'm making (turned into a very long term project) of a version of his "Egg Cup Stirling". The build log is on this site somewhere.
Let us know what you find. Thanks.
Hugh
Offline PJPickard
« Reply #2 on: February 18, 2022, 01:20:02 PM »
There is this too:
http://animatedengines.com/ltdstirling.html
James Senft has designed many Stirling cycle engines
« Reply #3 on: February 18, 2022, 02:17:13 PM »
Low delta Temperature engines, like the "cuppa model engines", typically have a displacer cylinder differential swept volume of about one hundred times greater than the power cylinder.
« Reply #4 on: February 19, 2022, 10:30:41 AM »
Thank you very much for your inputs they help tremendously.
