Author Topic: Cutting Skew Bevel gears(again)  (Read 2655 times)
Offline PJPickard
« on: February 14, 2022, 11:09:34 AM »
I've read all I can here and of course Kozo's work. Nearly all start with making your own cutters, including Ivan Laws' book. I get that "do everything" approach...but say you just want to buy a cutter and get on with cutting.
THe general method is to take roughing cuts with a slitting saw then finish with two cuts with the homemade cutter.
If you used a purchased cutter can(should?) you just make the 2 finish passes and skip the roughing?
Thanks!
Re: Cutting Skew Bevel gears(again)
« Reply #1 on: February 14, 2022, 02:58:14 PM »
When I make my bevel gears I use an involute gear cutter and use three passes.  The first is down the center between the two teeth, the next slightly above as described in Ivan’s book, and the last slightly below.  The last two cuts create the parallel depth bevels he describes.  I don’t make these often enough and I usually pull out Ivan’s book and brush up a little first.
« Reply #2 on: February 14, 2022, 06:52:41 PM »
PJ if you have my gear sheet spreadsheet it explains it on the sheet. Craig is correct with the three passes but if it’s a small gear two passes will work. Just don’t cut the center pass only he offset passes. If you don’t have the gear spreadsheets PM me with your email address and I will send then to you. The sheets covers Kozo method and making the button tool to make cutters toncut your own gears, plus  making a gear hob.
Regards Don
Offline PJPickard
« Reply #3 on: February 14, 2022, 07:49:11 PM »
Don,
I have the Skew Bevel Gear Calc Sheet Kozo Calculations Rev1. Are there others? Also maybe I missed the making a hob part, that sounds interesting for sure!
Nice work on that sheet, BTW!
« Reply #4 on: February 15, 2022, 04:32:04 AM »
Don,
There are many sheets in the Gear calculation sheets. To big a file to upload to the forum. Send me your email by PM and it’s safe with me will not be shared.
« Reply #5 on: February 15, 2022, 12:25:34 PM »
Skew bevel gears are a whole other exercise.  I made some when I built my replica Ford 9" differential.  With the help of Dave (Steamer) and Don I was able to make them. The don't just use one cutter per tooth but two, one for each side of the tooth. Kozo's article in Live Steam explains making skew bevel gears in depth.  I scanned the information but I can't post it because it belongs to Live Steam magazine.
Offline Dan Rowe
  • Dripping Springs TX USA
« Reply #6 on: February 15, 2022, 02:54:48 PM »
George,
 I have Kozo's book and saw that he designed the cutter with two different sides. Did you make a cutter or did you use two different off the shelf gear cutters to make your gears?
Cheers Dan
ShaylocoDan
« Reply #7 on: February 15, 2022, 03:58:21 PM »
Which one of Kozo's books has the skew bevel gear section?
Offline Dan Rowe
« Reply #8 on: February 15, 2022, 04:44:15 PM »
Chris, Climax locomotives used skew bevel gears.
Cheers Dan
ShaylocoDan
Offline PJPickard
« Reply #9 on: February 16, 2022, 11:13:20 AM »
Those books are now crazy expensive, I have all the Live Steam issues(from number 1 courtesy my dad who got it from the start( but another source is Ed Hume who built a class A Climax and used Kozo's methods. Ed is a funny and good writer, plus an excellent craftsman.
Here is a link to the book he did on the CLimax
https://www.amazon.com/Climax-Class-Steam-Locomotive-Model/dp/1545404895
And here is a link to Ed's photostream on the class A climax which has a lot of good pictures of the process
https://www.flickr.com/photos/edhume3/albums/72157649854075203
« Reply #10 on: February 16, 2022, 11:41:14 AM »
Hi Dan,
I made the cutters from drill rod and hardened them. I didn't make a first pass with a slitting saw bat took several steps with th finish cutter. When I get time today I will post a link to the video I posted on YouTube
« Reply #11 on: February 16, 2022, 02:04:23 PM »
I've seen used copies of Kozo's books going for well over $100 sometimes over $200, which makes no sense, since they are available new direct from the publisher for the same $50 they have been for years.
« Reply #12 on: February 16, 2022, 04:26:05 PM »
Here's some pictures of the cutters I made for the skew bevel gears and one of the finished ring gear
« Reply #13 on: February 16, 2022, 04:27:48 PM »
Here's a video of the finished ring and pinion gears being test run together.
<a href="https://www.youtube.com/watch?v=fW5wzl9lGaM" target="_blank">http://www.youtube.com/watch?v=fW5wzl9lGaM</a>
Offline Alex
« Reply #14 on: February 16, 2022, 09:51:31 PM »
Very well done!
