Author Topic: Tiny Super  (Read 4942 times)
Offline Ghosty
  • Ulladulla, Australia
Tiny Super
« on: February 11, 2022, 05:21:12 AM »
Hi All,
I came across this engine in a set of Popular Science mags from 1946. Looked like a nice little engine
Made a start on the cylinder.
Andrew
Re: Tiny Super
« Reply #1 on: February 11, 2022, 07:25:16 AM »
I love the early small engines and this one has character  :)
P.S. Its not that "Tiny"  ;)
Offline Zephyrin
  • near Paris, France
Re: Tiny Super
« Reply #2 on: February 11, 2022, 06:40:01 PM »
Tiny, not that tiny with 1" bore & stroke !
I also did oldtimer engines from this magazine, I will follow this build.
Offline Ghosty
Re: Tiny Super
« Reply #3 on: February 12, 2022, 03:58:33 AM »
Hi All,
Got some more of the cylinder done today.
Used an arbour to hold the cylinder, uses a 1/4" bolt with a 1/4x32 thread for the plug hole. I went with a 1/4" plug as the 3/8" plugs are getting harder to get, the 1/4" ones are readily available.
Machined the ports for exhaust and inlet. Set up in dividing head for the correct spacing.
Also machined the cooling fins, I like the look of the fins on the O&R engines, so I reconfigured the fins to suite.
The top of the head were machined with a 0.8mm slitting saw, and the cylinder fins with a 0.9mm HSS tool. Had to grind this one up.
Hope to get more done tomorrow.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #4 on: February 12, 2022, 03:59:57 AM »
Some More
Re: Tiny Super
« Reply #5 on: February 12, 2022, 12:49:46 PM »
Good looking cylinder  :ThumbsUp:
You didn't show, but I presume that you made the holes for the transfer port in the same setup too  :thinking:
Best wishes
Offline Ghosty
Re: Tiny Super
« Reply #6 on: February 12, 2022, 08:27:10 PM »
Best wishes
Per,
The lower transfer port will be cut in the cylinder lower flange after the transfer passage has been fitted.
Offline Ghosty
Re: Tiny Super
« Reply #7 on: February 12, 2022, 11:47:24 PM »
Hi All,
Done more, I do not have any black iron for the transfer port, had a 3/4" copper fitting, good enough, formed up and silver soldered to cylinder, then cleaned up.
Remounted the cylinder in the lathe and machined a couple of thou under sized.
Mounted in mill and machined cylinder flange, drilled mount holes, and machined out transfer port.
Then lapped and honed cylinder to size.
Mounted piston blank in lathe and machined to size, and cut ring grove.
Marked out positions for milling. Mounted in mill, drilled and reamed piston pin hole, machined transfer port, machined transfer and exhaust deflector's, machined piston internals.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #8 on: February 12, 2022, 11:48:45 PM »
More pics.
Offline Ghosty
Re: Tiny Super
« Reply #9 on: February 12, 2022, 11:49:35 PM »
A couple more
Offline Ghosty
Re: Tiny Super
« Reply #10 on: February 14, 2022, 07:02:06 AM »
Hi All,
Not a lot done today, machined up the ring blanks and tooling to finish of the rings. Got several done.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #11 on: February 14, 2022, 07:03:05 AM »
Some more
Re: Tiny Super
« Reply #12 on: February 14, 2022, 05:01:53 PM »
Are you heat treating your rings? There seem to be a number of different thoughts on this  ::)  :headscratch:  :wine1:
Offline Ghosty
Re: Tiny Super
« Reply #13 on: February 15, 2022, 01:50:35 AM »
Roger,
There is no not of it in the plans or writing, steel cylinder. I may heat treat a couple just to be safe.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #14 on: February 15, 2022, 01:51:36 AM »
Hi All,
Got into the crankcase today, machined to size, marked out, drilled and tapped mounting holes, set in 4 jaw chuck and machined.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #15 on: February 15, 2022, 01:52:35 AM »
And some more pics.
Re: Tiny Super
« Reply #16 on: February 15, 2022, 04:42:40 AM »
This build is moving along fast nice machining skills. Love the look of the cylinder and rings…   :Love:
Offline Ghosty
Re: Tiny Super
« Reply #17 on: February 16, 2022, 03:24:43 AM »
Hi All,
Had a big day today.
I could not get any bronze flat bar, so made some.
Cut a piece of round bar over length, cut of the big end cap piece, faced both and soft soldered together. Set in mill and using a slitting saw I got two pieces for con-rods.
Marked out, then drilled and tapped for big end cap bolts.
Drilled out holes and reamed big and little ends.
Turned up some arbours to hold the con-ron, mounted in mill and machined both ends and sides.
Swapped to lathe and machined both ends, then back to mill to finish the sides.
Drilled and cleaned up the oil holes in both ends of the rod.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #18 on: February 16, 2022, 03:26:08 AM »
More pics.
Offline Ghosty
Re: Tiny Super
« Reply #19 on: February 16, 2022, 03:27:20 AM »
And some more pics
Re: Tiny Super
« Reply #20 on: February 16, 2022, 02:52:43 PM »
That's some mighty nice looking work you are doing Andrew!  :ThumbsUp:
Offline Ghosty
Re: Tiny Super
« Reply #21 on: February 17, 2022, 05:32:01 AM »
Thank you.
Hi All,
Started on the crank today, cut piece to length, center drilled for crank and bigend center's, mounted in mill and hoged out big end.
Mounted on lathe between center's and machined big end.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #22 on: February 18, 2022, 04:20:38 AM »
Hi All,
Removed from lathe and re-set to machine crankshaft shafts, had to reset and glue in the crank spacer. Started with the front shaft, then machined the rear rotor/drum, drilled for crank webs and rough machined.
Machined up a jig to hold the crank and mounted in the mill and finished machining of the crank webs.
Removed the crank spacer and cleaned up the machining marks and edges.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #23 on: February 18, 2022, 04:21:49 AM »
And some more
Offline propforward
  • MN, USA
Re: Tiny Super
« Reply #24 on: February 18, 2022, 04:45:44 PM »
Wonderful - those are some great parts. This will be a fine engine when complete. Looking forward to seeing that!
Forging ahead regardless.
Re: Tiny Super
« Reply #25 on: February 18, 2022, 08:01:17 PM »
Great dokumentation and a fantastic result - really like that you kept the gluedin piece in place during so many ops - great idea  :ThumbsUp:    :cheers:
Offline Ghosty
Re: Tiny Super
« Reply #26 on: February 19, 2022, 05:25:55 AM »
Hi All,
Got the rear cover intake done today. machined rear cover, lapped in the crank, then machined outer part/intake of the cover in mill.
Set up crank and machined intake port.
Fitted intake tube to back-plate and checked the assembly.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #27 on: February 19, 2022, 05:26:36 AM »
A couple more
Offline Ghosty
Re: Tiny Super
« Reply #28 on: February 20, 2022, 01:03:33 AM »
Hi All,
Easy day today, went with electronic ign, machined up the pickup ring and prop driver, mounted prop driver and spot drilled the crank for the set screws to lock to the crank, made up a mounting plate, and ready to go.
Mounted on test stand and run, played around with the timing and mixture settings..
Got it running steady and consistent.
If anyone knows of any other OLD engine plans like this, could you let me know, always looking for them.
This is the end of the build.
Andrew
Offline Ghosty
Re: Tiny Super
« Reply #29 on: February 20, 2022, 01:16:47 AM »
Hi All,
Here you all are, running
<a href="https://www.youtube.com/watch?v=OCjZhzDk00A" target="_blank">http://www.youtube.com/watch?v=OCjZhzDk00A</a>
<a href="https://www.youtube.com/watch?v=RKlw5CEsm0o" target="_blank">http://www.youtube.com/watch?v=RKlw5CEsm0o</a>
Turn up the volume and enjoy.
Andrew
« Last Edit: January 14, 2023, 07:51:10 PM by Ghosty »
Offline Ghosty
Re: Tiny Super
« Reply #30 on: January 14, 2023, 09:06:07 PM »
Hi All,
Video link has been fixed.
Andrew
Offline vtsteam
Re: Tiny Super
« Reply #31 on: January 14, 2023, 10:13:39 PM »
Great engine. Love the sound. Throaty! :ThumbsUp: :ThumbsUp: :cheers:
Offline simplyloco
Re: Tiny Super
« Reply #32 on: January 14, 2023, 10:40:03 PM »
Love it! :cheers:
Re: Tiny Super
« Reply #33 on: January 15, 2023, 01:40:48 AM »
That's a great runner Andrew! well done.  :ThumbsUp: :ThumbsUp: :ThumbsUp:  :cheers:
Re: Tiny Super
« Reply #34 on: January 15, 2023, 02:55:47 AM »
 :Love:
Offline Zephyrin
Re: Tiny Super
« Reply #35 on: January 15, 2023, 08:41:15 AM »
great runner you have made, congratulations !
I see that you have replaced the contact breaker by a Hall sensor, but
the timing of the spark seems to be adjusted for once, and not on the fly
Offline Ghosty
Re: Tiny Super
« Reply #36 on: January 29, 2023, 07:46:55 PM »
Zephyrin,
I use a Rcexl ign box, has auto advance in it.
Andrew
