Author Topic: What is this tool for/  (Read 645 times)
Offline Swallowtail
« on: January 04, 2022, 07:05:01 PM »
Another item which appears to be shop bought, has bronze bush in the holder with a tool steel cutter held in the clamps. There are 3 or 4 of the bushes. I'm wondering if it's for turning small axles or the like. The previous owner was big into steam locos and I have a part finished one 'Rainhill' which I'm not sure what to do with. Got the plans and so forth.
Re: What is this tool for/
« Reply #1 on: January 04, 2022, 07:11:51 PM »
It is used to turn down long slender rods to a smaller diameter, the bush supports the work and the cutting tool is adjusted to take it down to the required diameter in one pass. Goes by various names such as running down tool, small diameter turning tool, etc.
« Last Edit: January 04, 2022, 07:15:25 PM by Jasonb »
Online steamer
« Reply #2 on: January 04, 2022, 07:37:27 PM »
I've heard it called a "Button Tool"....
Offline Swallowtail
« Reply #3 on: January 04, 2022, 08:22:59 PM »
Thanks for the inputs. I've had a look on YT and there are a few good examples of it in use, so I'll be hanging on to it
« Reply #4 on: January 05, 2022, 12:12:06 PM »
These used to be called a "box tool" by the old timers in the first two shops I worked in. Very handy for small dia rods to be taken down in diameter quickly - single pass to get to final diameter. A handy item to have. Was there a tobacco tin with it, containing about 80 different size bronze bushings for the tool?  :Lol: That was the traditional accessory for these tools in the shops I mentioned. "Erinmore Flake" was one brand on the tins I remember. :cheers:
Offline wagnmkr
  • Lindsay, Ontario, Canada
« Reply #5 on: January 05, 2022, 04:29:27 PM »
Used to smoke Erinmore Flake as part of a pipe mixture. Had a bunch of the tins at one point with small r/c electric bits in them.
I was cut out to be rich ... but ... I was sown up all wrong!
Offline Steve Crow
« Reply #6 on: January 05, 2022, 05:55:50 PM »
It is also used in horology. Called a slender turning tool by J. Malcom Wild. Apparently "based on the toolboxes used on Swiss automatics". There are a few photos and a description on page 108 of his Wheel and Pinion Cutting book.
I have been meaning to get round to making one for some time.
Offline Steve Crow
« Reply #7 on: January 05, 2022, 06:08:12 PM »
Looking at the photos in my book again, your tool looks identical to the Wild tool in every way. As Mr. Wild actually makes and supplies specialist tools to the clockmaking industry, I suspect it is one of his, if so, that will be a fine quality tool.
They are still offered on his website though with an improved design for adjusting centre height - http://www.j-m-w.co.uk/tools3.html. No price of course!
« Reply #8 on: January 05, 2022, 06:20:55 PM »
« Reply #9 on: January 05, 2022, 06:53:43 PM »
Clever little tool, the set of bushings looks very important, easy enough to make more sizes as needed.   :ThumbsUp:
Offline Steve Crow
« Reply #10 on: January 05, 2022, 10:49:06 PM »
Looking at the Chronos tool I think you are right. I didn't know they sold this. It still looks identical to the Wild one though.
