Author Topic: Howell Stirling Engine Fan  (Read 7117 times)
Re: Howell Stirling Engine Fan
« Reply #90 on: February 21, 2022, 10:37:03 PM »
Your stirling fan is really coming together.  I’m really enjoying this build.
« Reply #91 on: February 22, 2022, 12:20:01 AM »
Thank you, Per. A few small jobs still left to do, but yes, it won't be long now.
Dave and Craig, Thank you very much!
This morning I assembled the fan blades onto the hub using green loctite and set it aside to cure till tomorrow. Then I turned to making the Flame Guard. This is a pleasant hand fab job in thin brass sheet.
 “Chisels and hammers and files – Oh My!” (Dorothy, in a lost version of Wizard of Oz)
After annealing it was rolled around a piece of 1.5” aluminum rod and held with a hose clamp to set the diameter. Half was left hanging out beyond the bar so I could silver solder it. Then I turned it around to solder the other half.
Almost finished. The mounting tabs will get trimmed shorter, but they are used to screw it to the bottom of the Top Ring, so as to shield the lamp flame and the the lower part of the Hot Cap from drafts.
« Reply #92 on: February 22, 2022, 06:54:10 AM »
Hi Ron, I do love this fabrication work.
« Reply #93 on: February 22, 2022, 03:23:28 PM »
Wow, Ron - you are almost done with this sterling engine!  Can't wait to see it all up and running. I'm enjoying following your progress on this.  :popcorn:
Offline Dan Rowe
  • Dripping Springs TX USA
« Reply #94 on: February 22, 2022, 03:50:18 PM »
Hi Ron, I have been following this from the start and it is a fun build.
That should have been sung by the Tin Man according to the test audience.
Cheers Dan
ShaylocoDan
« Reply #95 on: February 22, 2022, 07:27:46 PM »
Achim, Kim, and Dan - Thank you!
The test audience has a good point!  :Lol:
« Reply #96 on: February 22, 2022, 10:15:26 PM »
Still following along... :popcorn: :ThumbsUp:
« Reply #97 on: February 23, 2022, 05:33:42 AM »
 :Love:
« Reply #98 on: February 25, 2022, 02:15:30 AM »
Thanks Bent; Thanks Don!
Almost there.
« Reply #99 on: February 25, 2022, 11:17:13 AM »
Matches the rest on the table very nicely (and that includes the heat source)  :praise2:
So what is missing besides "lighting the Fuse" ?
« Reply #100 on: February 25, 2022, 06:51:38 PM »
Looks nice!  Like Per said, when are you going to fire it up?  :popcorn: :ThumbsUp:
« Reply #101 on: February 25, 2022, 08:33:47 PM »
Thank you, Per!
Not much really. Attaching the flame guard and the usual final fiddling & fettling.
Thank you, Bent! Already have. First run video is below. That horrible knocking is exaggerated in the video, but it is there. Seems the displacer is just contacting the bottom of the cylinder. Once I correct that I'll post another video.
« Reply #102 on: February 25, 2022, 08:40:13 PM »
Wow!  Congratulations, Ron! That runs really well!   :ThumbsUp: :popcorn:
Are you going t make a blade guard for the fan, or just leave it OSHA unapproved?  :Lol:
« Reply #103 on: February 25, 2022, 11:11:01 PM »
Aside from the trapped shop elf knocking to get out out of the cylinder, its running great!!   :ThumbsUp:
« Reply #104 on: February 25, 2022, 11:45:48 PM »
Thanks Kim! I'm going to go ahead and live dangerously, at least for now.   ;D
Thanks Chris! Runs even better now that I let the elf out!  :LittleDevil:
I find I have to turn the volume on my computer down to at least 40% to make the video sound as quiet as real life. Anyway, I'm pretty happy with it. It's been a fun build, and I appreciate all the support and encouragement along the way. Thank you!
