Must be a production issue otherwise it would be random any ideas
It’s for a flywheel so not structurally important,I have been able to get rid of the marking but had to go 3mm deeper so looks like I need to get a piece of bar 10mm bigger to get what I want, just seems a waste, going to talk to the supplier on Monday see what they say.
It's not uncommon and is a consequence of manufacture. It is usually a surface effect. In the UK continuously cast iron is generally GR17, aka Grade 250, unless otherwise stated. It's a grey cast iron and machines very well, giving a smooth and uniform finish.Tne machined surface finish shown appears poor. So there is either something fundamentally wrong with the material, or the machining technique. Was the tooling HSS or carbide and what were the speeds and feeds?Andrew
Quote from: Steamingandy on December 18, 2021, 09:03:31 AMIt’s for a flywheel so not structurally important,I have been able to get rid of the marking but had to go 3mm deeper so looks like I need to get a piece of bar 10mm bigger to get what I want, just seems a waste, going to talk to the supplier on Monday see what they say.Wouldn’t a casting be far less wasteful? Is it just a lump or is there any detail to it ?Cheers Graham.
Please tell me what you need?I might just have it on the shelf….
