Author Topic: A Lightweight Husky  (Read 1642 times)
A Lightweight Husky
« on: December 03, 2021, 04:40:57 PM »
Having recently enjoyed making the Gamages and Bassett Lowke small marine steam engines the next engine to catch my eye while looking for something else was C W Woodson's "Little Husky" as it was a similar type engine and being a Uniflow would allow me to tick off making one of those too. It also had those tempting words "Requires no Castings"  :LittleDevil:
The original article appeared in Popular Science Magazine in 1944 and can be read here
There have been a few of these built on the various forums and even Julius has done a version but they all looked a bit heavy and bulky to my eye. So as well as redrawing it in metric I set about putting this little puppy on a diet and adding a few curves and features while I was at it. The main areas of attention are:
- Entablature and Base. Both made of thinner material and some additional machining to remove excess metal and add some shape particularly to the entablature and I also added some holes so it could be mounted in a hull if needed.
- Columns. Reduced in number from six to four, smaller diameter and also a bit taller with a tapered profile rather than just straight bar.
- Bearing Supports. A couple of holes to reduce bulk and separate bronze bearings added
- Cylinder / Valve chest. Rather than solder two cylinders together I cut this from solid. The valve hole was reamed right through rather than try and ream a blind hole to the end, this also made lapping the valve into the hole easier.
And this is what I came up with.
Re: A Lightweight Husky
« Reply #1 on: December 03, 2021, 05:49:33 PM »
I like the looks of that.  The exhaust piping would still be soldered/brazed to the cylinder?  Would it look any cleaner with a single pipe, or no pipe at all?
« Reply #2 on: December 03, 2021, 06:43:39 PM »
Yes I went for silver soldering the exhaust to the cylinder though it may be possible to use JBWeld and the odd screw.
I have seen images of a couple without the exhaust and can't see why a single one down the side would not work if the passages through the cylinder wall were all grouped together. Initial test runs shows it sounds rather good with a strong bark which may possibly have something to do with the twin pipes or could just be lucky timing.
« Reply #3 on: December 03, 2021, 06:55:45 PM »
Its running?  Videos!!
« Reply #4 on: December 03, 2021, 07:07:05 PM »
You should know me by now, I don't tend to post about an engine until the dust has died down from the  :pinkelephant: :pinkelephant: :pinkelephant:
I managed to get some paint on it this afternoon so hopefully it will still run when I put it back together and I can film it then. I could not easily video it during the test run as I did not have the hole at the top of the valve chamber covered (easier to see the valve inlet open and close for setting) so had to keep one finger firmly on that and the other hand to stop the silicon hose popping off.
« Reply #5 on: December 04, 2021, 06:34:08 PM »
I did not take many photos of this build but as there has been some interest shown by Pm and on other forums I'll add a bit of commentary to what images I do have.
Starting with the base a piece of 5mm plate was milled to the overall size and then the datum located following which the various 3mm holes were drilled.
Followed by milling out some of the unwanted material firstly by doing a few passes 0.2mm inside the line and then a full depth pass to remove the last 0.2mm of material. After this the holes for the bearing blocks and columns were countersunk on the underside.
Two pieces of 6mm thick material were squared up and then drilled & tapped M3, the spiral flute tap makes tapping a quick and easy process a syou don't need to keep backing the tap off to break the chips - just let them curl out the top.
It would be possible to just use a couple of CSK screws to hold the bearing blocks on or add a bit of JBWeld to get a fillet for that cast look but I opted to silver solder. Once out of the pickle the bearing holes were line bored , well actually drilled and reamed with an 8mm machine reamer.
I had intended to file the curved top to the bearing caps using a couple of buttons but realised I could do it on the CNC and at just over 60seconds each quicker than I could turn up the buttons. I left the oil holes until the end once the bearings had been Loctited into place drilling both at the same time.
Next up were the columns, after facing four pieces of 8mm stock to the same lengths one end of each was reduced to 7mm dia, drilled and tapped M3 and then a ctr hole drilled for later tailstock support.
The other end was reduced to 6mm and a 3mm spigot formed and threaded M3 then the end of the exposed thread rounded with a file.
It was then just a case of holding by the 3mm section, adding tailstock support and then setting over the topslide to turn the taper. A 2mm dia grooving insert left a nice 1mm radius fillet at each end of the taper to blend into the flanges.
The crank was just a piece of 25mm bar faced off and reamed 6mm then sawn off a bit over length. This was loctited to some 6mm PGMS and once set turned down to the finished 6mm thickness before transferring to the mill for tapping the M4 hole at a throw of 7.5mm. The pin was a simple turning job followed by cutting the saw slot with a slitting saw.
Offline Alyn Foundry
« Reply #6 on: December 04, 2021, 06:53:09 PM »
Hi Jason.
I guess no one asked because they already know the answer, but how is the steam that’s left in the cylinder at the bottom of the exhaust port dealt with on the upstroke? Won’t there be some compression?
Does it cool and become a negative or does the exhaust “ scavenge “ the cylinder like the Petter Super Scavenger two stroke Diesel engine?
Just curious really.
Cheers Graham.
« Reply #7 on: December 04, 2021, 07:05:12 PM »
I can certainly feel the compression and hear it pop when turning the engine over by hand. It would be less running with steam than the compressed air I'm using as it will be condensing as it cools but how much effect that would have at 1600rpm is debatable particularly once the engine has warmed up.
I guess this is why it has quite a hefty flywheel and needs a quite a bit more pressure than usual as the momentum is needed to get the piston back upto TDC
I don't think the exhaust does much as I have seen other uniflows with just the bare holes through the cylinder but it does look good ;)
« Reply #8 on: December 06, 2021, 07:09:34 PM »
I was in two minds as to what to make the cylinder from. Cast iron would have been nice but not so easy to solder the exhaust to it, Bronze and brass would have been easy to solder but it's a bit of a lump and I did not have much suitable in stock (at least that I wanted to cut into) so I ended up going for 230M07 (EN1A) as it's not really any more likely to rust than iron particularly as I'm mostly going to run on air.
So a piece was sliced off a 2" bar with the trusty Femi band saw, faced each end and then mounted on the CNC. The two ctr drilled holes are to make it easier to locate the bores for machining on the manual machines.
<a href="https://www.youtube.com/watch?v=hiJNyflwKdA" target="_blank">http://www.youtube.com/watch?v=hiJNyflwKdA</a>
While the mill was switched on I also did the entablature. The fit of the cylinder's spigots was very good into the holes and would have been a good press fit but that was a bit tighter than I wanted so a quick adjustment of the tool diameter in F360 and an extra 0.01mm was taken off the bores which gave a firm push fit.
<a href="https://www.youtube.com/watch?v=GH23zia1M58" target="_blank">http://www.youtube.com/watch?v=GH23zia1M58</a>
I then held the cylinder in the 4-jaw, clocked the ctr drilled hole true and then drilled and finally bored it out to 18mm
The valve hole was a bit too far off central to make holding in the 4-jaw easy so I used the mill to drill and ream the hole out to 6mm with a machine reamer
To make sure the cylinder cover holes were lined up correctly I screwed the cylinder to it's entablature and with a couple of 10-20-40 blocks between that and the fixed vice jaw was able to hold it true, locate bore and then drill and tap the four M2.5 holes and later the two M1.6 holes to retain the valve cover plate.
An existing mandrel was quickly altered so the cylinder could be held horizontally in the 5C indexer firstly to drill the inlet passage and then the three exhaust holes each side which are at 20deg spacings.
A suitable former was turned from delrin, the 8mm copper tube filled with lead and then bent around the former. I then clamped the "U" shape to a bit of MDF and used the boring head to cut the circular profile so it would slide over the cylinder.
Next the vice was swung round to a pleasing angle and using a long series milling cutter for non-ferrous material both ends were milled to the angle. After this the lead was melted out and the exhaust soldered to the cylinder, I had intended to have the slash cut facing upwards but changed the way I held things for soldering but forgot to turn the pipe up the other way. Still it saved having to paint the inside of the exhaust as it is now just in dark shadow.
After cleaning up the outside the last thing to do was lap the cylinder on a make shift lap turned from a scrap length of thick wall aluminium tube.
« Reply #9 on: December 07, 2021, 06:58:58 PM »
The piston was fairly straightforward turning and then over to the mill to drill and ream for the 3mm wrist pin before sawing off from the bar and facing the top.
The last item I have a photo of is the conrod which was cut from some 1/2" square brass bar on the CNC but I finished the other sid eon the manual machines.
The only other part of any note is the cam which I also did on the CNC but could quite easily be done with a rotary table. The flywheel, valve and valve follower were all basic turning so I did not take any pictures of them being made.
After putting it all together I did  need to make a little adjustment of the profile of the cam follower to get the valve to stay open for a longer period and up the pressure from my usual less than 10psi the engine was off and running with a good flick of the flywheel. It was then stripped for painting. As you can see there are not that many parts to this one which makes these little engines a nice change from the longer more complex builds.
And this is what they go together like
Running on about 30psi (note the balloning silicon tube) which it seemed to need to be able to get the piston back up to TDC. It is quite lively if not clamped down so could probably do with the plain disc crank web being shaped to add some counterbalance and the piston and conrod could also be lightened a bit if needed. 1600rpm Tacho reading if you can wait until the end.
<a href="https://www.youtube.com/watch?v=7vjvjQ2o6Uw" target="_blank">http://www.youtube.com/watch?v=7vjvjQ2o6Uw</a>
The next one in the series of these small marine engines is about to start being drawn up. I know some on here poo poo facebook and I don't frequent it that much but within an hour of asking on the right group for some key dimensions I had been provided with them along with several good photos of an original from 1926-28. so should end up with a fairly close reproduction Simplex.
EDIT. Images may be delayed as Photobucket is doing an update.
