Author Topic: Laser cutting tiny parts  (Read 692 times)
Offline Busted Bricks
« on: November 26, 2021, 01:29:40 PM »
The precision of my fiber laser cutter never ceases to amaze me. These tiny parts are cut from 0.5mm stainless steel. The small holes are 0.6mm diameter.
Re: Laser cutting tiny parts
« Reply #1 on: November 26, 2021, 06:25:17 PM »
I have a new fiber laser at work sitting in the crate on the receiving dock, we will un-crate it next week and move it into the shop the following week. It is a process because our shop is in the basement, we will also be removing a couple of machines that we no longer use. I'm looking forward to learning how it run it, and see what it can do.
« Reply #2 on: November 26, 2021, 06:36:44 PM »
Thats pretty impressive! How thick can it cut through metal?
« Reply #3 on: November 26, 2021, 07:58:40 PM »
How thick can it cut through metal ?
I bet that this is material dependant along with Laser Power and type ....
As Stainless is a poor heat conductor, I expect a lot thicker than for instance Aluminium or Copper that are really good heat conductors, and quickly disperse with the 'Cutting Power' ....
That said - I'm curious and impressed too  :cheers:
« Reply #4 on: November 26, 2021, 11:11:02 PM »
It's a 1kW machine so can cut 10mm mild steel and 5mm stainless steel.
« Reply #5 on: November 26, 2021, 11:12:37 PM »
Is it an engraver? Most cutters would be too big to go into a basement. Mine has a 2500x1300mm cutting area.
« Reply #6 on: November 26, 2021, 11:40:21 PM »
No it is a cutter, 50" X 52" work area. 1.5KW which should be fine for anything we need to do.
We have a large freight elevator with 16k lbs capacity. The 3 Haas VM2 machining centers in the shop that all came down the elevator, lots of other lathes mills etc. Most of the sheet metal enclosure had to be removed on the machining centers, we ordered them that way. The old NC punch we are removing will be fun, it weighs 8K lbs, good thing for riggers.:Lol:
This is our new machine.
https://kernlasers.com/laser-systems/fibercell/
« Reply #7 on: November 27, 2021, 12:19:01 AM »
Oooohhh... fun toy!
« Reply #8 on: November 27, 2021, 12:29:20 AM »
Looking forward to it, the punch that it is replacing is a 30+ year old cantankerous beast.
« Reply #9 on: November 27, 2021, 10:17:49 AM »
Dave, congrats! Very nice machine. Different league from my Chinese import. Mine is 3 years old now and has a Raycus source. Never let me down so far.
I did some experiments to see how small I could go. These name tags are cut from 1mm stainless. That's a pin in the foreground.
« Reply #10 on: November 27, 2021, 03:38:09 PM »
That's pretty impressive, are you using compressed air for cutting? have you tried any other gases, N2, 02?
« Reply #11 on: November 27, 2021, 07:54:09 PM »
Those tags were cut with N2. Since then I have bought a large compressor and use air instead. For carbon steel above 3mm I use O2.
