Engines > From Kits/Castings
Stuart No1 centrifugal pump
john mills:
I have a stuart no 2 i have it direct coupled to the virus engine with it drives with ease. the engine is 1" bore and stroke twin single acting
the no 2 pump is larger 3/4" inch pipes. i would think the engine you have would have plenty of power with the gear box to drive the pump
at a reasonable speed with out the engine having to rev as fast as the pump needs .you will find when you try it.
Steamingandy:
The pump will be supplying the cooling water for the condensers, it is an open circuit, so only the restrictions is the pipe work so I think this will copy happily.
Steamingandy:
All finished ticks over nicely
http://www.youtube.com/watch?v=6T_8E-L0Kto
RReid:
That's lovely work all around. Well done! :ThumbsUp: :cheers:
crueby:
The pump and engine are well matched now, love it! Just noticed what I think is a boiler feed water pump on the left end of the engine as well. :ThumbsUp:
Navigation
[0] Message Index
[*] Previous page
Go to full version
