Author Topic: 20cc Four Stroke Diesel  (Read 14980 times)
Re: 20cc Four Stroke Diesel
« Reply #60 on: July 20, 2022, 07:11:37 PM »
Not sure , the problem at the moment is the good weather and the mountains  :)
« Reply #61 on: July 20, 2022, 07:25:48 PM »
The next step was to cut clearances for the valves in the piston crown. The Keats was used again to hold the piston and the cut outs were started with a centre cutting 6mm end mill and finished with a 10mm cutter. All went well and there is just enough clearance without the 1mm thick head gasket.
« Reply #62 on: July 31, 2022, 06:44:44 AM »
The next step was to lap the valve with 20 micron diamond paste. I use a small drill chuck to hold the stems. The sealing O ring for the cylinder liner was then fitted, taking care the the clearance scallops for the cod rod didn't cut it.
The piston rings were spares that I made for the two stroke version of the engine. As the bore was lapped to the same plug gauge they fit nicely. I then realised I had forgotten to drill the camshaft oilway in the crankcase so I had to dismantle the bottom end again.
« Reply #63 on: July 31, 2022, 06:53:57 AM »
The head, valves and crankcase then had a clean up in the ultrasonic bath and on with the assembly. The valve timing was set for approximately equal overlap at TDC. It can be finely adjusted later. I then saw that I couldn't tighten the grubscrew on the crankshaft sprocket so I opened up the chain. While I was typing this I realised that I just had to turn the crankshaft 90°  :facepalm2:
Offline MJM460
« Reply #64 on: July 31, 2022, 12:53:31 PM »
More good progress Roger.  Still following along and learning heaps.  The detail really comes through in your pictorial posts.  Much appreciated.
« Reply #65 on: August 01, 2022, 08:03:56 AM »
Thank you, I'm glad you find it interesting  :ThumbsUp:
A few more bits. I am going to have to modify the compression tester to fit this cylinder head so a bit more drawing required. I started setting up the injection timing and found that I hadn't finished the replacement injection pump tappet. I probably left it until I could confirm the length. It was parted off to length and faced. Then came the fun task of milling the locating groove to keep the roller follower on track. The first version was cut with a slitting saw but the set up was rather complex so for the next one and this one I milled the slot with a 1mm end mill. The slot was taken to depth, 1.2mm, in 0.1mm steps at 18 000rpm and then opened out to 1.4mm in 0.05mm increments using a 1.4mm drill as a gauge.
Finally I cut the recesses in the M4 grubs screws used for the valve clearance adjusters with a 3mm carbide radius cutter.
« Reply #66 on: August 04, 2022, 06:04:18 PM »
Next I started modifying the compression tester and making new clamp plates for it and the injector. Due to space restraints this engine has the fixing studs at 14mm rather than 16mm.
The hexagon was reduced to 8mm diameter, leaving a 2mm spanner flat. I also had to slightly chamfer the tip to clear the piston. There is around 0.3mm collision. The new clamp plates are made from 2mm thick bright strip. This raised a new problem as my spot facing cutters have recess above the pilot so the first attempt drifted off position. I was able to keep the second attempt on centre and finished them off with some filing buttons. This had to be done in two steps as the larger diameter is the same as the fixing hole centres.
« Reply #67 on: August 07, 2022, 05:40:34 PM »
The new clamp plates seemed to fit so the next step was to make a punch template for the head gasket. This was made from a strip of 50 mm wide aluminium much as before. There are two 4mm dowels to keep everything in place and the two new punches ,4.5mm and 8 mm, were made from silver steel and hardened.  The 25.5 mm cylinder bore punch is case hardened steel from some earlier engine builds.
The injection pump tappet was hardened at the same time.
« Reply #68 on: August 07, 2022, 05:58:43 PM »
The gasket template was set up on the faceplate to bore the cylinder hole. Every thing was deburred and cleaned ready for the first gasket which seems to fit  :)
With it all clamped together some problems appeared  :( The exhaust valve was leaking and the conrod was hitting the top of the liner  ::)  I took it apart again and could see the contact marks on the conrod and liner. I eased the liner with a little filling and also noticed that there was a lump of Hymolar in the camshaft oil passage  :toilet_claw:
The valve leakage was due to a tiny bit of something on the valve seat.
It was assembled once again and I made a couple of pushrods from 3mm music wire, cut with a disc in the Proxxon hand tool and profiled on the bench grinder. They may be a little short but will do for the first trials.
I fitted the compression tester and gave it a quick spin with the drill:
<a href="https://www.youtube.com/watch?v=Gu3i6eY_BXM" target="_blank">http://www.youtube.com/watch?v=Gu3i6eY_BXM</a>
It reaches around 22 Bar, 320 psi, with no lubrication other than a bit of rust preventing maintenance spray. OK for a start. There is still a little contact between the conrod and the liner, Maybe the liner is rotating  :thinking: it is not positively located.
« Last Edit: December 04, 2022, 04:50:33 PM by Roger B »
« Reply #69 on: August 07, 2022, 11:09:44 PM »
I see that you have made quite a bit of progress Roger  :ThumbsUp:
I'm sure you will find the last small details  :cheers:   Oh - and nice compression for first try  :ThumbsUp:
Offline Brendon M
« Reply #70 on: August 12, 2022, 01:31:49 PM »
Doesn't seem like much longer now until it runs :)
« Reply #71 on: September 04, 2022, 06:55:45 PM »
A little bit more progress on this. There were a number of small problems to fix, the injection pump tappet fouled the camshaft bearing housing, the spacing between the follower and the cam was too much, the injectors needed chamfering slightly to clear the piston and the split link on the cam chain fouled the oil pump body.
The injector nozzles were held in a 6mm spring collet and chamfered 0.5 mm.
A relief was milled in the camshaft bearing housing with a 6mm end mill and 1mm was milled from the injection pump guide. The injection tappet clearance can then be adjusted if required by putting a shim under the guide.
The injection pump seemed to assemble properly so I moved over to the oil pump. Two small recesses were milled in the body with a 6mm end mill and it was cleaned and refitted.
« Reply #72 on: September 04, 2022, 06:58:08 PM »
The next steps are to make a temporary mount for the oil tank from the two stroke and make a chain tensioner for the cam chain. The oil pump will just by used to feed the two main bearings and big end. The third outlet will be blanked off.
« Reply #73 on: September 04, 2022, 10:35:05 PM »
There is a big amount of small details that really matters a lot more than a superficial glance would give a clue about .... and some of them you never know until something went wrong first .....
I believe it's called Experience  :old:
Godd to see that you are making progress again Roger  :cheers:
« Reply #74 on: September 10, 2022, 02:59:31 PM »
The chain tensioner arm was sawn and filled from 2mm bright steel.  A 10T sprocket was thinned down to remove the grub screw hole an opened out to 8mm. Two Oilite bushes were slightly thinned down so they just met in the middle.
The shaft was turned from 4mm silver steel with a groove for a retaining E clip and silver soldered into the arm. It is held in place using one of the M4 holes that used to fix the injection pump.
The oil tank is supported by a bracket from the bits drawer. Together with the pipe it should be stiff enough for the first trials.
