Thank you Alex. At the moment I think I can see where the spray problem is using a piece of white paper. The problem is more how to modify the nozzle to get an even distribution of droplets and not a selection of different sized blobs.
Next the fixing holes for the body were coordinate drilled, referenced to the bore and one milled edge. With the previous version that was made from a rectangular block these holes could just be marked out from the edges. These holes were spotted through to the body and drilled and tapped M2.
Next the base was profiled, as before, using some 6mm filing buttons. Finally I turned a thin wall bronze bush and pressed it in, followed by reaming 5mm again.
I will now move back to the Junkers thread to finish and assemble the injection cam and rocker.
https://www.modelenginemaker.com/index.php/topic,8690.405.html
