Thank you both
Per, I have thought about indirect injection, it makes the injection theoretically easier but increases the heat loss due to a larger surface area combustion chamber. The current four stroke diesel combustion chamber is about as small as it can be. There's a poster on HMEM i am following who is looking at building an indirect injection diesel.
Dave, I'm not too worried about the actual pattern at the moment, just the atomisation. Previously while I was trying to work out how to keep everything concentric it was important and someone (possibly Per?) pointed out the vibration of the pipe. The spray from the needle and mushroom injectors lights easily, the jet from the open nozzle just makes my lighter oily. With a much faster pressure rise in an engine turning at 2000 rpm rather that me pushing the handle on the test pump things may be different
