Also interesting is the associated injection nozzle, which differs from the others in that the path of the spring-loaded nozzle needle is limited by a soft ring made of synthetic rubber. The interaction of rubber disc and spring means that a very good atomization of the fuel at the nozzle opening is achieved at large and small flow rates, regardless of the prevailing injection pressure.----------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------...edit....I can’t yet work out exactly what the rubber disc/ring in the injector does.
