. This may be where Find Hansen's small injector shows it's benefits
He said he is using methanol and glow plug ignition as it is much less sensitive to mixture variations than petrol/gasoline and spark ignition.
Thank you Minh Find Hansen’s video clip shows the injector being fed by a test pump which delivers much more fuel than would be used in a running engine. The details on here state a 2mm pump plunger and a working stroke at idle of 0.03mm.https://findsminimodelhotbulbengines.dk/Aboutmymodelmaking.htmlThose are similar dimension to the ones on my engine. He also states that the injector needle is 0.9mm diameter which is similar to my latest design.
Surely, the Honda Monkey Bike would use a low pressure indirect port injection, whereas you are striving for high pressure direct injection into the combustion space. I do not believe methanol will combust on compression alone, hence the glow plug.
Hello Minh,As Find Hansen is using a feedback governor which will compensate for the tolerances he could end up with such a small working stroke although I agree it does seem rather small, 0.3mm is a more reasonable figure if allowing for losses.
