fumopuc: Nice. Likely a lot easier to dig a broken milling tool out than a broken tap.Dave: Formed soft jaws. Another reason to obtain a 3D printer.Thanks.
That's single point thread milling, where the tool can cut a variety of threads limited by the thread depth and the ramp angle ground into the teeth. With a blind hole like this example you want to spiral upward as the swarf falls below. With the through house ramp down as the swarf falls out. The same tool can cut left or right hand threads, internal or external.Something to consider is SFM in defining feedrate. SFM using only tool diameter and RPM fails because tool path isn't straight. This is true of any arc toolpath, but can be important with small tools. Internal Feed = [(Major Thread Dia - Cutter Dia) / Major Thread Dia] x Linear FeedExternal Feed = [(Major Thread Dia + Cutter Dia) / Major Thread Dia] x Linear Feed
