Some rapid progress Internal O ring grooves are somewhat tricky
I had to increase the feed at bit and also to repeat the last turning around two times, to get a fine usable M2 tread.
Hello Achim,I am sitting back quietly watching your progress and admiring your workmanship, it looks very good. The great thing about how we build our model engines is the wide verity of challenges we face and the need to find cleaver ways to create them. After weeks of fabricating cylinders and glueing O rings you now change to CNC machining the cylinder heads. Plenty of challenges, plenty of innovative solutions leading to the biggest prize: plenty of satisfaction.Cheers Mike
Still happily, if quietly, following along with your progress, Achim. Lovely work!
