Hello Chris,Thats very much the American way of direct ploughing a field, but I guess fields over there can be a lot bigger than ours.Over here in England, fields used to be ploughed by a pair of ploughing engines with huge winch drums under their bellies. The engines would position themselve on either side of the field and take turns (bouts) pulling a six furrow plough back and fore.This is my 2" scale Fowler 16 HP single PE. That big cylinder could realy bark when it was working hard.Mike
The plough in this thread only has one blade but it's quite a big one https://www.modelenginemaker.com/index.php/topic,2550.msg109055.html#msg109055
Quote from: Vixen on October 03, 2021, 11:37:17 PMHello Chris,Thats very much the American way of direct ploughing a field, but I guess fields over there can be a lot bigger than ours.Over here in England, fields used to be ploughed by a pair of ploughing engines with huge winch drums under their bellies. The engines would position themselve on either side of the field and take turns (bouts) pulling a six furrow plough back and fore.This is my 2" scale Fowler 16 HP single PE. That big cylinder could realy bark when it was working hard.MikeYeah, out in the midwest part of the country the fields disappear out of sight before the next road sometimes.I picked up a set of plans for one of the big plowing engines like you show, its on my list but other fun projects keep jumping the queue! Beaut of a model, that plow assembly alone must have taken a while to make!
As I also said Jo's BB1 is having all the same sort of modifications done including a boiler redesign but she has got a bit further with hers which is in this thread. One only has to look at the first couple of posts and see se has the same views as me as the drawings "leaving a lot to be desired" or are "downright wrong" yet I don't see anyone jumping down her throat so what's the problem with me having the same views?https://www.modelenginemaker.com/index.php/topic,2547.0.html
I have a starting point in the Hanning drawings but as I mentioned they leave a lot to be desired A lot of his design has been overly simplified, some things are downright wrong but for a 40 year old design John Hanning did a lot better design on this engine than I could have at the time.
We know you are a comparative newcomer to model engineering and may not appreciate just how much John Hanning and Colin Tyler were respected in their day.
My understanding when Mike said this:Quote from: Vixen on October 07, 2021, 05:15:27 PMWe know you are a comparative newcomer to model engineering and may not appreciate just how much John Hanning and Colin Tyler were respected in their day.Was that he was referring to the fact that he was reading Model Engineer back when John and Colin published their design and consequently he appreciated how model engineering had to be done back then and respected them for it. Malcom Frost's 1997 design of the A7 Fowler was from the outset intended to be a scale model and is not intended to be constructed solely on a 3 1/2" lathe as John Hanning mentioned in the second of his 1966 series on the build of the BB.
