This post will go over making the connecting rod. I modified this extensively from Upshur's original plans, mostly because I wanted to, but also because I thought some aspects of the original design wouldn't stand up well over time. Unfortunately the side effects of my modifications were added complication and added time to build it. But in any case, here goes!
I started with a piece of 5/16" thick Al and after squaring it up and bringing it to the spec'd dimensions, I drilled and tapped w holes for the ron rod cap bolts, the top portion being drilled out clearance size for 4-40. I also drilled a small center hole in what will shortly become the rod cap.
Then I used a slitting saw and cut off the rod cap.
The rod and rod cap shown on the print. You can see the clearance size holes in what will be the rod cap and the 4-40 tapped holes in what will become the rod body.
I made some 4-40 threaded studs from a bit of brass. I very carefully turned a piece of .125" rod down to .112" and then thread it with my home-made tail stock die holder. You'll see the reason for making these studs shortly.
And the two pieces reattached using the studs and some model pattern nuts.
Back to the mill locating a number of features and drilling center holes at 4 points to define the to-be shape of the con rod. I also carefully located, drilled, and reamed the holes for the wrist pin and for the big end. These are larger than Upshur's original plans called for and you'll see why shortly.
Here you can see the big end after reaming to the final size, which in this case is .4375". You can see why I used brass studs as they are partially cut when reaming to the final size. I also increased the rod cap thickness a bit as I needed more meat on that piece given the much larger hole in the big end.
I also milled an extra feature on the top end, essentially a 5/16" square extension as the original stock is 5/16" thick.
Then I installed my small tooling plate and located the big end and also made sure the part was parallel to the x axis using a DTI.
Next I plunged in a .25" 2 flute end mill at the 4 locations previously located. I actually didn't need to locate them earlier as I used the DRO again this time and used an end mill anyway. The 4 cuts start to define the to-be shape of the con rod.
And here you can see the rod with the operations done so far laid on the print for comparison.
And here you can see the reason for the larger hole at the wrist pin end. I turned a simple bushing from SAE 660 bearing bronze and you can see it here laid near the con rod.
And here it is pressed in place with a little Loctite 638 applied before pressing in place.
And here's the start of milling one side of the con rod to a 2 degree angle with respect to the centerline. I'm using a 3/8" 4 flute end mill and I placed a 2 degree angle block under the part.
Then I turned the part over and this time placed a 4 degree block on top of the previously milled edge and set it level using a DTI. If the starts are aligned, this should also give a 2 degree angle on this side of the con rod.
And the con rod against the print with the operations done so far. You can start to see where this is going!
Now over to the lathe. You can see the reason for both the center hole in the rod cap and for the mysterious 5/16" feature milled on the top of the rod. I'm holding that end is a 5/16" square 5c collet.
Here's some of the lathe work. I rounded the wrist pin end with a right hand tool, but had to change to a left hand tool to round the big end of the rod. I'm using a CCGT insert in a 5/8" shank tool holder. I find that these inserts work very, very well on Al.
Here's a pix of the current progress on the rod when laid on the print.
And here's another pix from the rod's side so that you can see the shape from this perspective.
And by now probably everyone has figured out that I'm gong to attempt to make and install a split bronze bushing for the big end of this con rod. So I had a piece of 3/4" SAE 660 bearing bronze and shown is turning it down to .625" to start the process of making the split bushing. Shown is a short length turned to .625" and being parted off.
And here's the bearing bronze shown on top of the print which shows how the bushing will be made.
Then over to the mill with the stock installed in a collet block and being split as deeply as I could with a slitting saw. I used the thinnest saw I had, .012" so that I removed the smallest amount of material possible.
And the split bearing bronze after parting it off from the main bit of stock.
Over to the welding table showing the materials I'll be using. I've roughed up the flat sides of both pieces using some 120 grit emery. For this sort of soldering, I like to use the 'tinning flux' type material as it has some finely ground solder within the flux. I'm also using the Harris 4% silver "lead free" plumber's solder. I find that this solder melts beautifully and bonds well.
After fluxing both halves of the bronze material.
And here's the operation ready to proceed. I secured the two halves together with a couple of twists of some annealed steel wire. Heat will be applied by this very standard plumber's torch.
And here's the part after soldering. I applied heat to the body of the part and then touched the solder to the top of the 2 pieces when they got hot enough. The solder wicked completely through both parts and was visible at the side seam and at the bottom of the parts when completed. This is the top of the part after soldering.
And here you can see the bottom of the part after soldering. Notice the solder flowed completely through the joint.
Since the part is not truly round anymore, I went back to the lathe and was still able to grip it with a 5/8" collet even though it's oblong about the amount of the cut. During this operation, I took the OD down to .562", still oversize for where I need to end up, but now that end is completely round.
And here's the bronze after turning one end back to round. The solder joint is barely visible after turning the OD down.
I didn't show the operations on the lathe was it was just some turning to the final OD and creating the .437 OD with a groove/turn/parting tool. Here's the bronze to-be bearing on the print.
Next was over to the mill with the part installed in a collet block. Shown is aligning the solder line as close to horizontal as possible, just by eye and comparing it with a parallel for reference. After I got it as close as possible, I took it back out of the vise and tightened the collet securely.
Then I created the relief areas for the 4-40 cap screws by plunging in with a .125" end mill. I located the end of the part and the centerline and using the DRO to place the cutter appropriately.
Checking the fit of the con rod big end on the bushing. I wanted to make sure there was sufficient clearance for the cap screws before tearing the setup down.
And here's the bushing on the print showing the relief areas.
I didn't show the remaining operations on the lathe. I was going to but things happened rather fast. First I drilled thru the part and then reaming it .001" under 5/16". I then went to part off the bushing and just when the parting operation completed, the part actually split right at the solder line. I think what happened was that there simply wasn't enough material left to withstand the pressure from the parting operation. But luckily the bushing halves were completely fine and their shown against the print, along with the con rod and the brass studs that were sacrificed during drilling/reaming the big end of the rod.
Then back to the rod. Here's the setup to remove the holding piece from the small end of the round and to round it over. I made an alignment pin for the center of the rotary table, .75" by .1875" to center the rod. Then I placed a scrap piece of Al under the rod and secured it with a couple of toe clamps, centered the RT under the spindle, moved off by the radius in y and rotated the RT to round the end.
And here's the rod with the small end rounded. It's interesting how the two rounded features intersect and make what I think is a rather nice looking feature.
Here's a close up view of the small end of the rod with the operations done so far.
Next the thickness of the rod body needs to be reduced from .3125 to .25" everywhere except at the small end. So I reinstalled it on the rotary table, moved out the radius plus 1/2 the cutter diameter and rotated the table 360. I repeated the same operation on the other side of the rod also.
And here's the small end after thinning both side using the rotary table.
Then back to the tooling plate to then the remaining sides of the rod. I secured it and then moved the toe clamps as necessary to get to all parts of the rod body. When I flipped it over, I placed a bit of flat, scrap Al under the previously milled area and moved the clamps as required to remove the material from the current side.
And here's the rod profile after the thinning operation was completed.
Then, since the bushing isn't guaranteed to be perfectly round, and I'd reamed it undersize, I then reamed it first to 5/16" and then finally to .001" over size. I did this just by hand with the reamer in the bench vise and turning the rod by hand.
Lastly, I drilled a 1/16" oil hole in both the small end and the big end. My thought is that I can periodically put a drop of oil on both of these locations and hopefully that will be good enough given this is bearing bronze. The bushing halves fit quite securely in the rod and rod cap but I also put a small drop of Loctite 638 under each half of the bushing prior to installing and tightening down the rod cap.
And here's the wrist pin, piston, and con rod ready for assembly.
And here's all the major parts assembled and checked for rotation. I do notice that the piston skirt protrudes below the cylinder bottom by about .20" or so. Is that correct? I can't find any mistakes in the dimension so I assume so, but I'd like to be sure.
And here's a pix from the top when at TDC. The piston is also about .20" below the top face of the cylinder which I also assume to be correct, but I'd like anyone with experience with this engine to comment.
And that's finally it!
One of the other reasons I built the con rod this way is that I next want to build a Farm Boy and the con rod design for that engine is very similar to the way I built this one so I felt that this was a good way to gain experience.
Sorry for the length of this post, but I did want to give sufficient detail for others to attempt the same.
Enjoy!
