I figured a good next job would be to top the cylinder with a cylinder head. Basically a straight forward turning and drilling operation. I planned from the beginning to go with the side mounted spark plug option, but I haven't drilled the spark plug hole yet, preferring to wait until I have the plug on hand, or at least know for sure what plug I'm going to use. Ron, just a quick hint based on what I ran into on my engine build, but I've not yet documented in my build thread. I think it's likely that the SAE standard nuts you should will interfere with the rocker post whenever you install it. I ended up making some brass washers 5/16" x .050" and some model scale nuts .219" across the flats by .140" in height. Those cleared fine when I tried them.FYI.MIke
