By the way a edge finder can do very good job of picking up a round part....but it usually takes two goes from the X and Y to do it...
......... I built my first machine with homing, and would never do without.If using an encoder index pulse with a limit switch to home it will be as accurate as the resolution of the encoder. The accuracy of the switch doesn't come into play. Emco stepper machines have excellent homing with an index signal and a prox.
You say you built your machine with 'homing' and would never do without. Well, I have never had a 'homing' capability, therefore I dont know how to use the 'homing' facility or what advantage it would bring.
Quote from: Vixen on September 10, 2021, 08:06:56 PMYou say you built your machine with 'homing' and would never do without. Well, I have never had a 'homing' capability, therefore I dont know how to use the 'homing' facility or what advantage it would bring. I have active limit and homing switches. As I said previously I try very hard to avoid using the limit switches. The homing switch is never used (by me) for referencing the tool to the workpiece. Instead it allows the entire system to remain centered. If I continually reference the workpiece with an edge finder I can accidently make the machine start to work more and more off center. Eventually this could cause a run-in with the soft limit stops.LinuxCNC requires homing before it will run, so I do not have much choice in any case. (Requirement probably can be defeated, but I have not tried.)Gene
I guess I'm in the minority here, I have working plus and minus limit switches on all three axes of my mill. I can full rapid into any switch and it slows and stops with out any issue; this is due to properly setup soft limits. It is also nice when loading a job file you know if there are boundary issues before you start cutting.My machine is a converted knee mill so there are some extra variables that come in to play, I.E. knee position or ram position on the turret that may cause you not to be able to cut your entire job without repositioning something.I'm using industrial quality snap action switches (Omron) with a spring loaded roller actuator. Testing has shown that these switches will repeat to within .001", plenty good considering the rest of the hardware.Dave
You say you built your machine with 'homing' and would never do without. Well, I have never had a 'homing' capability, therefore I dont know how to use the 'homing' facility or what advantage it would bring. Perhaps you would be kind enough to give me a short 'how and why' primer.I have just checked my Emco VMC. It still has the magnetic index and proximity sensors and wiring for each of the X, Y and Z axes still in place, but they are not interfaced to my Linux CNC controller at the moment. Perhaps I am missing a trick by not using the 'homing' facility.Mike
Hello Hugh,I am well past the age of ever being invited to work in an industrial machine shop and selfish enough not to let anyone else use my CNC machines. So I can devise my own simplified way of working. I have physical markers on each axis to show the extent of travel, so it is easy to position the vice (or vertical chuck for round stuff) well within the available travel limits. I only use (workpiece) part zero, so dont need to bother with offsets (G5xxx etc) . I find it quicker (and safer??) to set Z zero, off the work, after a tool change. Again, this avoids measuring and setting tool heights into a tool table, and yet more offsets.Simple and lazy, yes. It works in my shop but I would be a disaster in another workshop.Mike
I'd like one of these then you could machine whole crankcases in short time and bring back all those long lost designs where castings are no longer available. QuoteYou don't need all that fancy stuff to machine a crankcase. With a little planning and careful setup you can do a crankcase fairly easy. This was 6 setups, no homing switches, manual tool changes on a $1300 scratch built milling machine.
