OK 1 step forward, and 3 bask..... If you look at the machined parts above closely, you will see that the gears CAN"T mesh.... OK....drop back and fix it. I redrew and simplified the pump, .....correctly this time.I also decided that it nees a lot less volume. so I gear reduced it...as is prototypicalMy gear cutters are here, and I have another piece of bronze! Off to the mill!!!
Quote from: steamer on February 27, 2022, 03:31:42 PMOK 1 step forward, and 3 bask..... If you look at the machined parts above closely, you will see that the gears CAN"T mesh.... OK....drop back and fix it. I redrew and simplified the pump, .....correctly this time.I also decided that it nees a lot less volume. so I gear reduced it...as is prototypicalMy gear cutters are here, and I have another piece of bronze! Off to the mill!!!I'm confused about the picture in that post, the straight gear on the top shaft, next to the bevel gears, looks to be off to the side of the gear below it? Shouldn't it be meshing with the gear below, like it was in earlier pictures??
Chris I think it's this pic that shows the pump gears won't mesh as either the ctrs are wrong or the pockets not a big enough diameter. Would have thought that would show up on the simulation in F360 which basically shows what the machine is going to cut and you could have seen there was not enough gap between the pockets for the gears to mesh.
I believe Chris means the picture attached here. The gear A (crudely arrowed) should be moved over - which is what Dave was saying - a broken mate. I get that in solidworks plenty, just the same as Fusion 360 I'm sure. The number of times I've put an assembly away, only for it to fly all over the place when I open it the next day..............
Quote from: propforward on February 28, 2022, 05:53:10 PMI believe Chris means the picture attached here. The gear A (crudely arrowed) should be moved over - which is what Dave was saying - a broken mate. I get that in solidworks plenty, just the same as Fusion 360 I'm sure. The number of times I've put an assembly away, only for it to fly all over the place when I open it the next day.............. Happens with Alibre too, if you don’t get everything constrained properly.Dave: many ways to get it wrong, only one way to get it ‘right’. You’re making progress, regardless of the setbacks. Looks GREAT.Back when I was a student in engineering, a student asked the professor once, “Professor, why don’t you give partial credit for test answers that are nearly correct?”.I loved he’s answer, “When you get it ‘almost right’ the rocket still blows up”. Classic!
