What Mike says. Mostly. However I would say that for this sort of size of model a valve clearance of 0.010" is more than necessary or desirable.Firstly, if the valve clearances are not accurately set, then your acceleration curves and such are thrown to the wind. Accurate setting means you do not really need a lot of clearance.Secondly, a large clearance on the base circle radius makes it difficult to design the ramps between the clearance and the bottom of the flank. At least not if you want a cam that looks as though it has a continuous smooth surface.As I ground the cams for my Seagull, I decided I could halve ET Westury's recommendation, and went for 2-1/2 thou, and that seems to be working nicely.I designed them with ramps in the form of a radius connected to the relieved base radius by short tangents, like this exaggerated diagram:
Quote from: RReid on February 06, 2024, 12:45:52 AMOn my DOHC Halfa build, I adjusted the valve clearance mostly by shaving bits off the valve stems, rather than the buckets. I did do the shell game with the buckets initially to get the best starting points.I'm going to start by making the parts as identical as I can....it will be a touchy process as I started with some prototype parts this past weekend. boring the two parts will be the way forward. I need to hold the depths of the bores tight on both of these parts. So I'll need to make up a nice boring bar for this....Also I need to confirm the buckets don't go "Potatoe chip" on me when I harden them. Well At least no too muchDave
Quote from: steamer on February 07, 2024, 12:52:33 AMQuote from: RReid on February 06, 2024, 12:45:52 AMOn my DOHC Halfa build, I adjusted the valve clearance mostly by shaving bits off the valve stems, rather than the buckets. I did do the shell game with the buckets initially to get the best starting points.I'm going to start by making the parts as identical as I can....it will be a touchy process as I started with some prototype parts this past weekend. boring the two parts will be the way forward. I need to hold the depths of the bores tight on both of these parts. So I'll need to make up a nice boring bar for this....Also I need to confirm the buckets don't go "Potatoe chip" on me when I harden them. Well At least no too muchDaveWhat would cause parts to warp in hardening? Is it evenness of heating, or something in the quench itself?I didn't get all the subtleties in the cam discussion, but still wowed by the model!
Quote from: crueby on February 07, 2024, 01:09:10 AMQuote from: steamer on February 07, 2024, 12:52:33 AMQuote from: RReid on February 06, 2024, 12:45:52 AMOn my DOHC Halfa build, I adjusted the valve clearance mostly by shaving bits off the valve stems, rather than the buckets. I did do the shell game with the buckets initially to get the best starting points.I'm going to start by making the parts as identical as I can....it will be a touchy process as I started with some prototype parts this past weekend. boring the two parts will be the way forward. I need to hold the depths of the bores tight on both of these parts. So I'll need to make up a nice boring bar for this....Also I need to confirm the buckets don't go "Potatoe chip" on me when I harden them. Well At least no too muchDaveWhat would cause parts to warp in hardening? Is it evenness of heating, or something in the quench itself?I didn't get all the subtleties in the cam discussion, but still wowed by the model! Heating up thin walled parts to cherry red and quenching in oil....If I can fixture it so I can quench it symmetrically, I might stand a chance. It all takes some thought.....but who am I to tell Crueby about planning ahead!
Impressive fixture. Does your CAM sort out the trunion offsets?Mike
The trunnion is just for the inclined surfaces for the valves, cam tunnels ect.Dave
