Good way to contour the caps and part them off in one go, avoids the bolt heads getting in the way if you do the contour on the whole part.Will you tap in the CNC or don't you have that facility as I noticed you did not seem to do it for the crank webs.
I think you can see the stainless steel wallet used to prevent oxidiation of the item being heat treated.
