Author Topic: 1/4 scale Porsche 917 180 degree V12 Build  (Read 58535 times)
Re: 1/4 scale Porsche 917 180 degree V12 Build
« Reply #390 on: December 05, 2022, 07:54:54 PM »
Dave,
On vacation, it's good to sit down and have the time to get cought up with your build. One question, how much of a gap between the two halves of each throw? I am following that the bearing in between locates the faces. Presumably the gap doesn't matter so much. I do have a pdf of the Schilling book but "mein Deutch ist sehr schleckt" is there an English version available? Wonderful work!
« Reply #391 on: December 05, 2022, 08:23:51 PM »
Dave,
Im shooting for an .0005 interference fit.   :ROFL:  As a bush it is that, and the caps close up completely, and the bush is immobile.         That's the target anyway....we will see.
the fixture is going to be a key component in this operation, splitting these bushes exactly in half is what Im going to try to do.     Then I'll need a fixture to hold them for final boring and finally reaming while clamped.....it's going to be tedious at best!     this is pushing me to a level of consistency that I'm not sure I can do....but I will try...and the only down side of trying is scrapping some bronze bushes....so the risk is pretty low.....comparitively.
And no I don't know of an English version of this book, though Mike and I have had some luck using the Google translator.  At the end of the day, the drawings speak pretty well for themselves.
« Last Edit: December 05, 2022, 08:32:20 PM by steamer »
« Reply #392 on: December 05, 2022, 09:01:45 PM »
Thanks!
« Reply #393 on: December 06, 2022, 02:19:12 AM »
First pair fit perfect!    On to the rest
« Last Edit: December 06, 2022, 06:19:57 AM by steamer »
« Reply #394 on: December 06, 2022, 02:25:04 AM »
YeeHaw!! Lookin' great, Dave.
« Reply #395 on: December 06, 2022, 02:43:06 AM »
Beautiful!
« Reply #396 on: December 06, 2022, 05:30:14 AM »
15 pairs of bearing shells up to op2.  They need to be drilled....but not tonight.
« Last Edit: December 06, 2022, 06:20:57 AM by steamer »
« Reply #397 on: December 06, 2022, 11:30:10 AM »
Looking good  :praise2: Are you going to finaly ream the bores when they are assembled or are the production tolerances tight enough?
Online Vixen
« Reply #398 on: December 06, 2022, 12:16:57 PM »
15 pairs of half bearing shells from 30 complete bearing rings :praise2:      Well done, you have not lost any yet :praise2:
But you must have got through a whole lot of bar stock and made a mountain of shiny chips. Shame you cannot find a use for the undersize half of the bearing shells.
« Reply #399 on: December 06, 2022, 01:01:10 PM »
Oh far from
Killed 3 on op1
Killed 4 on op 2
Had to make more last night to get 15
Went through 18" of 1/2 " bronze bar.
And I still have more ops to do!
« Reply #400 on: December 06, 2022, 02:43:09 PM »
I'm building a locating fixture to bore and then ream to final size.
Offline jcge
« Reply #401 on: December 09, 2022, 09:27:44 AM »
Dave - this typ.912 engine is one of my favourite engineering designs.
Really enjoying the way your going about this build and documenting and sharing it.
Regards
« Reply #402 on: December 09, 2022, 04:03:18 PM »
Regards
Thank you John,   Im trying     The machining challenges of this engine are pretty epic to me.    I rarely have to do 12 of anything, and making 12 exactly alike...or as close as I can get....has been a real challenge to me    It's upping my game for sure!
« Reply #403 on: December 09, 2022, 04:26:17 PM »
Oh far from
Killed 3 on op1
Killed 4 on op 2
Regards
Observations on my mill while making these bearings.   After the 4th bearing I noticed that the fixture was being rubbed by the cutter during the cut....the first 4 did not do that    I checked for chips under the fixture, but I didn't find any, and it was starting to cut bad parts....hmmm
The cutter was in it's holder tight, and I wasn't removing the tool holder between parts, and the tool was taking a .010" facing cut in bronze.....so it was very unlikely I was pulling the cutter out...and the amount was very small....  I checked the cutter and it wasn't worn.    OK...so the machine tool Engineer in me screamed "Thermals"
The only coolant on the machine is mist lube ( compressed air/mist) and as it was bronze i wasn't using it.    As the spindle was running at 4000 rpm, and it was a couple of minutes long cycle,   I suspected that the spindle nose/toolholder were warming up and growing in length......
So I added coolant to the program, and I aimed the air jet at the middle of the tool holder.      Let it sit for a minute or 2 and tried again but now with coolant on.
It immediately started to behave like the first cut!    Ha ha!   so I then cut the rest of the 30 parts that way  ( 38 or so in total including the scrap ones.)  and the tolerance was +/- .0005' which considering it's not a precision mill by any means,  was pretty good!!!
Just some of the things you run into when you're running "production"...which is something I rarely do.
Online Vixen
« Reply #404 on: December 09, 2022, 04:42:49 PM »
Hello Dave,
"Thermals"..... Yes, they can be a problem with repetitive work. It's one of the reasons I do little machine shop work during the winter months. The machinery is my unheated outside workshop can get very cold overnight. If I put the fan heater on to get the shop warm enough to work in, the machines get a thermal shock, slowly start to warm and expand. Any ideas about maintaining tight tolerances go out the window.
Mike   :atcomputer:
