Author Topic: The Le Rhone 9C  (Read 58773 times)
Re: The Le Rhone 9C
« Reply #120 on: October 12, 2021, 10:32:55 PM »
That looks Great Craig!...  45 years huh, I'm just a youngin!.
My cylinders have flats on the sides.....parting blades REALLY don't like that so saw it is
Re: The Le Rhone 9C
« Reply #121 on: October 13, 2021, 06:41:50 PM »
I had originally written the name as a typical American mashup of the names - the LeChrone...but she may be an old engine, but far to pretty for that epithet.   :hellno:
I'll go sit in the corner now. :toilet_claw:
Re: The Le Rhone 9C
« Reply #122 on: October 13, 2021, 08:14:03 PM »
Ha!  The LeChrone… just in time for Halloween
Re: The Le Rhone 9C
« Reply #123 on: October 13, 2021, 08:37:00 PM »
 :facepalm2:
Re: The Le Rhone 9C
« Reply #124 on: October 14, 2021, 12:31:58 AM »
Wait I thought Leckrone was the UW band director? :ROFL: :lolb:
Re: The Le Rhone 9C
« Reply #125 on: October 14, 2021, 06:42:21 PM »
No, Art, that's Brad McDavid...
https://music.washington.edu/people/brad-mcdavid
 ;D
Re: The Le Rhone 9C
« Reply #126 on: October 14, 2021, 07:25:14 PM »
Bent - Art's right too.  Leckrone was the UW (University of Wisconsin, Madison) Marching Band Director from 1969-2019.
It's them cheese-heads fault, there's just too many UW's to keep straight.  There's 13 different UW's and a total of 26 UW campuses.
« Last Edit: October 14, 2021, 07:33:06 PM by ddmckee54 »
Offline Bjorn_B
  • Sweden
Re: The Le Rhone 9C
« Reply #127 on: October 14, 2021, 08:31:46 PM »
OH man  that's a cool animation!
The rod bearings have always puzzled me.....waiting for the long awaited clarification!!!
Good onya man!
Me too, I can't get my head around this. I'm double-puzzled..  :thinking:
Re: The Le Rhone 9C
« Reply #128 on: October 14, 2021, 08:41:24 PM »
Hi Craig,
I was looking again at the second half of that animation, seeing more every time I look at it. Am I right that this engine didn't use the one 'master' connection to the central bearing disc like a lot of others did? Looks like the slots/arcs keep things lined up as it goes round rather than the one non-pivoting one I am used to. Very very clever setup - whoever invented that was a mechanical marvel!
Re: The Le Rhone 9C
« Reply #129 on: October 16, 2021, 11:04:10 PM »
Hi Chris
There seems to be conflicting information regarding the rods.  I thought I had first read where the engine had a ‘master rod’ that attached solidly to the disk where the other eight rods had slippers.  In researching further I found many references that led to believe that all nine were slipper rods with none of them a ‘master’.  It seems to me that either would work, and the ‘final’ version in my design uses nine slipper rods with none a master and I’ll probably go with that unless someone posts and clears up this mystery, showing that the Le Rhône had a master rod after all.
I have some detail photos of the disk that attaches to the crankshaft and it uses ball bearings between the disk and the crankshaft so obviously, the slipper disk is no meant to rotate with the crankshaft but rather remain in a somewhat stationary orientation with regards to the slipper bearings on the rods.
« Last Edit: October 16, 2021, 11:07:29 PM by Craig DeShong »
Re: The Le Rhone 9C
« Reply #130 on: October 17, 2021, 11:51:44 AM »
Hello Craig LeRhone,
Have a look at this. There may be a job vacancy for you.
Unfortunately you may have left it a bit late to apply.   :Lol:
Keep up the good work
« Last Edit: October 17, 2021, 08:39:34 PM by Vixen »
Re: The Le Rhone 9C
« Reply #131 on: October 17, 2021, 05:33:39 PM »
Well Dang Mike, another opportunity missed. :facepalm:  Although, at the rate this engine is going together, the Allies might have been woefully short of aircraft engines. ::)
Re: The Le Rhone 9C
« Reply #132 on: October 17, 2021, 06:01:58 PM »
Don,
Thanks for coming to my defense. Been away doing fun anniversary sorts of things. Only just now found someone mistake the Wisconsin UW for the other UW, the one without Mike Leckrone.
Craig it will be interesting to see how slipper rods work.
Offline Laurentic
Re: The Le Rhone 9C
« Reply #133 on: October 17, 2021, 07:23:37 PM »
Craig - re your Reply#129.  I think you are on the right path with all nine slipper rods going into slots; I seem to remember watching a Youtube vid a while back showing how a Le Rhône was but and I'm pretty sure all nine rods were just slotted in, the slippers had slots built in to overlap adjacent rods and the slippers had a pointy end on one end and a corresponding vee cut out the other.
Nice work so far on this build if I may say so.
Online Twizseven
Re: The Le Rhone 9C
« Reply #134 on: October 18, 2021, 05:11:41 PM »
Craig,
The Modern Aviation Engines books I picked up a few weeks ago describe the Le Rhone Connecting Rod arrangement as follows:
"The connecting rods are provided with "feet" or shoes on the end which fit into grooves lined with bearing metal which are machined into crank discs revolving on ball bearings which are held together so that the connecting rod big ends are sandwiched between them by clamping screws.  This construction is a modification of that used on the Anzani six-cylinder radial engine.  There are three grooves machined in each crank disc and three connecting rod big ends run in each pair of grooves  The detoils of this construction can be readily ascertained by reference to explanatory diagrams at Figs 393 and 394A.  Three of the rods which work in the groove nearest the crankpin are provided with short shoes as shown at Fig.394B  The short shoes are used on the rods employed in cylinders number 1, 4 and 7.  The set of connecting rods that work in the central grooves are provided with medium length shoes and actuate the pistons in cylinders numbers 3, 6 and 9.  The three rods that work in the outside grooves have still longer shoes and are employed in cylinders numbers 2, 5 and 8."
Hope this is off some use.
Best Regards,
Colin
Just had a further look in book and Figs 391 and 392 give a very good view of how the connecting rods are connected into the grooves.
There are short paragraphs and drawings on the following topics:
Le Rhone Valve Actuation
Le Rhone Carburetor
Le Rhone Engine Action
The valve timing, cylinder positions, firing order ere detailed in these drawings
« Last Edit: October 18, 2021, 05:32:38 PM by Twizseven »
