Per: haven't decided completely on castor oil, that was a good lubricant back then; but oils have come a long way.
QuotePer: haven't decided completely on castor oil, that was a good lubricant back then; but oils have come a long way.Oh, I know .... it was a bit of a Tongue in Cheek comment - especially when you consider the Famous Side Effects of using Castor Oil
Quote from: Admiral_dk on August 15, 2022, 11:29:20 PMQuotePer: haven't decided completely on castor oil, that was a good lubricant back then; but oils have come a long way.Oh, I know .... it was a bit of a Tongue in Cheek comment - especially when you consider the Famous Side Effects of using Castor Oil A-Hah! So you would have me running to the jiffy-John I’ll remember that Per.
Even with modern Oils it will still throw it around - so do not expect to be clean afterwards + think about what to wear.Per
Craig,Your best bet is to always stay on the propeller side of the engine when it's running. Mike
I ... hold those old timers in very high regard as well.
