Author Topic: The Le Rhone 9C  (Read 27838 times)
Re: The Le Rhone 9C
« Reply #495 on: June 18, 2022, 12:31:48 AM »
That's a big job for such a small job! Plenty of impressive machining going on in your shop. :ThumbsUp:
Re: The Le Rhone 9C
« Reply #496 on: June 18, 2022, 11:14:42 AM »
I should start by mention that I'm not a machinist or very good in this game + you shouldn't sell yourself short here ..!!!.. as I'm sure everybody are rather impressed with your builds  :praise2:
Second I see that I got it the wrong way around - it isn't the Cams that you tweaked, but the followers and I do understand that given the complexity .... Thank you very much for a detailed show and tell  :cheers:
Re: The Le Rhone 9C
« Reply #497 on: June 18, 2022, 04:07:22 PM »
Couldn't agree with Per and Ron more here.  You do a lot of impressive work and I'm constantly amazed with your builds!
Re: The Le Rhone 9C
« Reply #498 on: June 20, 2022, 09:11:23 PM »
Ditto those comments above.  Building at small scale can be ridiculously difficult, because the realistic tolerances required also diminish with the scale, in some (many?) cases.   Looking good, Craig! :DrinkPint:
