Author Topic: Large containers for pickle solution  (Read 2479 times)
Re: Large containers for pickle solution
« Reply #15 on: September 21, 2021, 07:09:15 PM »
For sugar, the common conversion is 12.5 grams per level teaspoon, so that would be closer to 20-ish for a heaping tablespoon. For citric acid, the amount is not very critical. If you add more than will disolve in, it will just leave some on the bottom, not a problem. I tried citric acid once, found it was easier to just use 5% white vinegar from the grocery store. Still pretty cheap, no mixing needed, and not toxic or nasty on the skin.
« Reply #16 on: September 21, 2021, 08:24:12 PM »
Like Chris said, the citric acid concentration is not critical. I have no idea what mine is, though it is certainly less than saturated.
« Reply #17 on: September 21, 2021, 11:06:54 PM »
Hmm.... I think there are 3 teaspoons in a tablespoon - or did you mean 12.5g per level tablespoon?  That kinda makes more sense.
For citric acid, the amount is not very critical. If you add more than will dissolve in, it will just leave some on the bottom, not a problem. I tried citric acid once, found it was easier to just use 5% white vinegar from the grocery store. Still pretty cheap, no mixing needed, and not toxic or nasty on the skin.
OK, sounds like it's not super critical, so I'll just go with something and give it a go.  I can always add more if I want to :)
Thanks Chris and Ron!
« Reply #18 on: September 21, 2021, 11:10:48 PM »
Kim - yes, my brain transposed teaspoon for tablespoon!   :zap:   I had looked up the amount for both, and blew it when typing in the results. Sort of like mixing up baking soda and baking powder - results can look right but work (and taste) terribly!!
« Reply #19 on: September 21, 2021, 11:15:01 PM »
:Jester:
Been there, done that!
