Author Topic: MY TAKE ON RUDY'S RADIAL  (Read 6259 times)
Re: MY TAKE ON RUDY'S RADIAL
« Reply #30 on: November 01, 2021, 07:15:28 PM »
Interesting idea, to use a pin to keep the throw in position  :ThumbsUp:
How tight / small tolerance did you have between the hole and the pin ?
Offline sid pileski
« Reply #31 on: November 01, 2021, 09:07:22 PM »
It was a press fit in the aluminum, and a tight slip on the crank.
In fact, when I was turning it in the lathe, I did not secure it by any other means.
I did take light cuts and the cuts are obviously always trying to push it on the dowel pin.
Sid
« Reply #32 on: November 01, 2021, 09:11:54 PM »
Sid
Looks great Sid, and just in time.  I think I’ll steal  your idea for holding the crank  :NotWorthy: when I get there with my model.
Offline sid pileski
« Reply #33 on: November 06, 2021, 09:07:01 PM »
Today's update:
« Reply #34 on: November 07, 2021, 12:21:04 PM »
Coming along very very nicely! :ThumbsUp: :popcorn:
Offline sid pileski
« Reply #35 on: December 06, 2021, 05:22:46 PM »
Here is an update on my progress:
Making the heads.
Next, I'm going to make the air tubes to the heads. The rotary valve is done.
At this point, when the tubes are complete, it should run!
Sid
Offline sid pileski
« Reply #36 on: December 14, 2021, 05:03:37 PM »
Question for those of you that have built this engine-
Did you drill the exhaust ports in the cylinders per his plans?
At this point, I have not included them.
My engine is up and running now.
I wonder if it would run any better/different with them?
It seems to run well enough on low pressure and has a nice sound to it.
Sid
« Reply #37 on: December 14, 2021, 05:29:14 PM »
Hi Sid. I did include the cylinder exhaust ports on my engine. After I had it running, I taped those ports off as an experiment. I noted no difference in operation, but the sound changed slightly. With the ports open the individual exhaust beats are more distinct. Closed, with all the exhaust coming out the back of the valve, they blend more, giving a slightly more muffled, smoother note. The difference is not dramatic, but is noticeable.
Looking forward to seeing your beauty shots, and hopefully a video?
Offline sid pileski
« Reply #38 on: December 14, 2021, 06:02:58 PM »
Soon. Still have the rocker boxes to make and solder in place as well as the air tubes.
Need to make the faux exhaust tubes and the running stand.
Need to retire!!
Sid
« Reply #39 on: December 14, 2021, 06:06:12 PM »
I put the exhaust holes in, per plan. But I never did the experiment that Ron did.  I assumed it just eased the exhaust path since the exhaust path out through the valve is a much longer, smaller diameter path.  But clearly (according to your and Ron's experience) those holes are not required :)
Offline Dreeves
« Reply #40 on: December 15, 2021, 02:18:58 AM »
Sid,  looks great. I sure hope to see it at Cabin Fever in January
Offline sid pileski
« Reply #41 on: December 15, 2021, 02:40:13 AM »
Dave- not sure I'm going.
My buddy has already bowed out.
Probably kind of late to find a hotel now??
Sid
Offline sid pileski
« Reply #42 on: January 09, 2022, 10:37:33 PM »
This one is pretty much all done.
<a href="https://www.youtube.com/watch?v=RCHBbyUIruc" target="_blank">http://www.youtube.com/watch?v=RCHBbyUIruc</a>
« Reply #43 on: January 09, 2022, 10:45:51 PM »
« Reply #44 on: January 09, 2022, 11:42:36 PM »
Wow!  Very nice!  I love the color combination you chose.  The black looks great with the brass!
And it runs great!   :ThumbsUp:
