Author Topic: Edge Pro Tram  (Read 6910 times)
Offline rick41
Re: Edge Pro Tram
« Reply #15 on: August 12, 2021, 07:55:36 PM »
Hi Kim,  Not wanting to beat a dead horse to death.  The problem I have with tramming my mini-mill is that it is difficult for me to move the column the exact amount needed as indicated by the first tram.  I usually end up loosening the bolt securing the column and tapping it with a rubber hammer until the readings are the same and then when all is tightened it may be off by a couple thou or so and repeating the exercise.  I agree that  when I built my tramming device, I made it so that both indicators were facing forward.  Agreed, that is a pain in the ass to try and read the indicators when turned 180 deg.  I solved that problem by rotating each indicator by 90 deg.  I have attached a picture of my tramming tool.  Not pretty, but it works.  I usual tram my min-mill when starting a new project.  Someone mentioned that the pattern left when fly cutting is a good indicator.  I agree.  Rick
Offline Mike Bondarczuk
Re: Edge Pro Tram
« Reply #16 on: August 12, 2021, 08:50:56 PM »
Rick,
Good ides to have the two gauges back to back so to speak and a move I had not thought of.  :old:
Certainly saves a crick in the neck trying to read the backwards facing one.
Offline Hugh Currin
  • Box Elder, SD, USA
    • www.currin.us
Re: Edge Pro Tram
« Reply #17 on: August 12, 2021, 09:55:44 PM »
Rick:
I have a home made tramming tool with only  one indicator. I use it as you describe. Zero the indicator, rotate 180 degrees, then set the indicator half way back to zero. This is essentially a calibration. Then adjust the tram to zero the indicator. Finally rotate back 180 degrees and check that it's still reading zero. The tram is OK if both positions read the same, but zero is an easy reading to aim for. This requires some gymnastics (or a mirror) to see the indicators from both sides.
Kim calibrates both indicators at one point, the same point for both. He can then use the tramming tool without further rotating the spindle. It would speed tramming as I need to go back and forth several times.
I think John Bogs' is slightly different. In his the tramming tool bracket bottoms out before the indicators do. To calibrate he just presses the tool against a flat surface, like a surface plate, and zeros both indicators. Now, as long as the bottom of the tramming tool is perpendicular to the shaft of the tool, it's calibrated. You did machine the bottom to be perpendicular to the shaft didn't you? Just put in the spindle, align perpendicular to the axis being trammed, and adjust tram fill both indicators read the same, may not be zero.
Anyway that's my two cents worth. I have to build me one one of these days.
I don't understand the need to calibrate the tool.  I made a copy of this tool several years back and I use it as follows.  I put he tool into a collet lock it and snug it up.  I then lower the head until the indicators are both firmly touching the mill table.  I then set the dial on each indicator to zero.  I carefully rotate the indicator 180 deg and note the readings.  If both are reading zero, the mill tram is OK.  To adjust the tram if it is out, I note the readings and adjust by 1/2 the difference in readings.  May takes me couple iterations to get it spot on.  Basically the same procedure as adjusting a surveying level.  Rick
Hugh
Re: Edge Pro Tram
« Reply #18 on: August 12, 2021, 10:15:03 PM »
Rick,
Nice tramming tool!  And I see what you mean about turning the indicators like that so you don't have to read one of them backward.  I guess the only time one would be backwards now is if you were tramming for head nod, right?  Or do you turn the indicators around for that?
I wouldn't worry about beating a dead horse to death!  That's a great way for people (like me) to understand a slightly different point of view.  I have one way I've been looking at things and to understand the subtle difference between two methods it takes belabouring the details.  And in the process, I (hopefully) learn something new, or about some assumption I've been making without even realizing it.  So to me, these kinds of discussions are good for learning.
Jason,
I meant to say thanks for posting that link to Bog's post.  I remember that now but clearly had forgotten about it.  I know many people have used this kind of tool before and I think there have been several posts about it. But I didn't really understand how they worked till I got one in my hands and started using it.  And then it all made sense.
Hugh,
Some very insightful remarks.  Thank you.  The tramming you describe is exactly what I've done up till now, using a single indicator.  But with this very rigid bracket and two indicators, it really is a treat to tram the mill now :)  Much less frustrating than the old single-dial method I used before.
I also didn't remember about Bog's calibration method.  As you said though, that method depends on having the bottom of the tramming tool perfectly perpendicular to the rod that is held in the collet. But unless you recalibrate the Pro-Tram every time you put it in the collet, I think you're still depending on that same perpendicularity.  Interesting thought experiments here...
Thanks,
Re: Edge Pro Tram
« Reply #19 on: August 13, 2021, 01:21:32 PM »
As long as we're discussing options I'll mention my approach which I learned from an online video (sorry, too long ago to remember video details).
Essentially, it boils down to the same as Hugh's home made single indicator version, but using a "back plunger" indicator. The indicator's plunger extends from the back of the case so that the dial faces up. Not as much gymnastics are required to read the dial in any position.
Re: Edge Pro Tram
« Reply #20 on: August 13, 2021, 01:39:48 PM »
In much the same way I just use a lever type indicator set with the dial facing upwards.
And once you have the spindle trammed to the table don't forget to chuck that the head and quill also move in the same plane you may have to make a small compromise somewhere.
<a href="https://www.youtube.com/watch?v=jp4sqaAw11Y" target="_blank">http://www.youtube.com/watch?v=jp4sqaAw11Y</a>
Re: Edge Pro Tram
« Reply #21 on: August 13, 2021, 08:22:08 PM »
As all my mills are fixed head machines and it only needs doing once its not really worth bothering with a plate or glass, may be different for those with rotating heads of adjustable tables.
I assume same applies if using these tram tools as you need to rotate them too though I've only ever seen them being used direct on the table?
Re: Edge Pro Tram
« Reply #22 on: August 15, 2021, 12:53:49 AM »
This afternoon the 'mini' version of the Edge Pro Tram that I had ordered arrived. The mini version has a 3" span rather than the 6" of the larger one, and has a 1/4" shank vs 1/2", so it fits better on the Sherline mill.
Very interesting - turns out the tram was out by 10 thou over 3" the way I had the headstock mounted. By loosening the headstock holding bolt (which allows removal or rotation of the headstock) and lifting it to one side to retighten, I could get rid of over half of it. Since I have the mill riser block in, which gives more reach over the table, doing the same on the riser block let me get rid of the rest of the error. The Sherline has a square key in a slot under the headstock and under the riser, which gets the position very close, but there is still just a little qiggle room to the fit on it. The tram in the other direction, in line with the column, was good.
The check and fix of the tram took maybe a minute overall - quite quick and easy. I've noticed in the past that sometimes I was not getting it square, easiest to tell with things like the fly cutter and larger end mills, when seeing the pattern it would leave as it went across a surface, but never had a good way to measure or correct it. On the lathe, where I rarely move the headstock, I would check the alignment before boring pistons/cylinders to make sure I would not get a tapered cut.
Quite happy with the purchase! Given how often I add/remove the riser, it will be well worth it. Thanks for posting about it Kim! I also looked through their catalog, and saw the mill end stops they sell, those would be very easy to make to fit my t-slots on the table, I had been bolting down the 1-2-3 blocks as stops for long items, the style they make would be an easy, um, imitation, to make for myself. This tram is something I could have made, but it would have taken a bunch of time, and also the cost of some bar stock plus two good inidicators which is not that much savings. If I rarely changed the headstock setup, it would be less worth it and could make do with other methods.
Re: Edge Pro Tram
« Reply #23 on: August 15, 2021, 01:00:36 AM »
Pictures please!!!     something like that would be nice on the Aciera F1
Re: Edge Pro Tram
« Reply #24 on: August 15, 2021, 01:06:12 AM »
Here ya go!
Given that my mill table has some obvious scratches in it (it does get just a wee bit of use) I tried it with and without a piece of flat plate - got same readings both ways, and with the plate it didn't dropt the tips into the slots when turning it to measure the lean in the column (none). It comes with a little magnetic post for calibrating as mentioned in earlier posts here, since my mill table is aluminum it just stuck itself to the indicator tip rather than the table! Other than that it worked great. Checked it rotated around the axis to make sure that the drill chuck was not introducing any error, it was not. Holding it in a collet would be better, but I dont have one for the headstock.
Re: Edge Pro Tram
« Reply #25 on: August 15, 2021, 01:08:33 AM »
Oh, and I ordered it online, Edge Pro themselves sell it on Amazon, shipping from the factory, for a few bucks less for shipping cost than ordering it direct from the factory website. Price for the unit itself was the same, but total was a little less. Go figure!
Re: Edge Pro Tram
« Reply #26 on: August 15, 2021, 05:27:16 AM »
That's interesting...  I ordered mine via Amazon too (through the Edge store of course).  I'm betting that through the Amazon site, Amazon takes care of fulfilling and shipping the order so it comes with "Amazon shipping rates" which are probably lower than anyone else can get. due to their distribution networks.
Glad you like it Chris!  I sure do :)
Re: Edge Pro Tram
« Reply #27 on: August 15, 2021, 07:08:42 AM »
Despite suggestions earlier in the thread do be careful if using Gauge plate or Ground Flat Stock to run the tool against as despite it's name the FLAT only differentiates it from round stock. Tolerance is something like 1mm over 1m length so a 150mm square which I what I would need could be 0.15mm out.  ::)
The material is "flat" while it is being ground on the bed of the grinder but can bow or get accidentally bent if poorly stored or handled.
Offline Zephyrin
  • near Paris, France
Re: Edge Pro Tram
« Reply #28 on: August 15, 2021, 09:44:43 AM »
in the small Unimat SL1 I had ages ago, the tramming of the mill drill was quickly made  :
I screwed the face plate on the broach and pushed and hold it dead flat against the table of the machine while locking the head on its support on the column, it was fast and very effective.
I agree the it cannot be done on a large mill with an heavy head...
Offline propforward
  • MN, USA
Re: Edge Pro Tram
« Reply #29 on: August 29, 2021, 07:09:01 PM »
I've not been in the shoppe or on the forum so much of late owing to various (all positive) personal happenings, but I thought I'd add a bit more to this, just a couple of comments / suggestions, mainly aimed at anyone totally new to the hobby who might be looking at this. I trammed my mill again yesterday, as it was clearly out - nearly a 2 thou sawtooth in the Y direction. Not nearly as bad in the X.
I have to tram my Y axis by shimming under the column, there is no fine adjustment. I got it all done about as well as can be expected on an import hobbyist mill I think. I cannot feel the ridge between cut paths with my thumbnail, and perhaps more importantly can't see a sawtooth under a straight edge any more.
Anyway, I did get caught out briefly during the process, by troublesome and errant swarf / fine metal chips. These got under the spacer block i was using for calibrating the dual dial indicators, under the indicators themselves and also under the column. Once I realized what was going on I got that taken care of quickly, and luckily it didn't take long to firgure out. A good blast of compressed air under the column seems to have cleared it - before that I was not getting consistent behaviour as I changed shim thicknesses, but afterwards the direction of tram went with the change in shim thickness each time and I soon had it dialled in.
So, that's my observation, when tramming, be very careful about dirt, dust, debris, burrs and chips getting under your measurement faces etc (a practice we should all be following all the time anyway), and not only that but be aware of any dings or raised spots on your table, and stone off if need be.
Also when I checked tram, I performed it on both my milling vise and my table to look for differences, and was very pleased to find none.
I followed up by lightly skimming a tooling plate I acquired to get it flat, and was pleased with the result. Review on that elsewhere.
Forging ahead regardless.
