Author Topic: Uniflow Engine  (Read 1966 times)
Offline gary.a.ayres
Uniflow Engine
« on: July 14, 2021, 11:28:01 PM »
A simple uniflow engine based on a design by Stan Bray.
The mechanical design follows SB's original plans scaled up to x3.5, but much of the layout and appearance of my version are my own.
<a href="https://www.youtube.com/watch?v=071Zh0OVfcU" target="_blank">http://www.youtube.com/watch?v=071Zh0OVfcU</a>
Dimensions (excluding wooden plinth) -
Overall length:     450 mm / 17 5/8 inches
Frame width:     145 mm / 5 ¾ inches
Overall width (including crankshaft):     300 mm / 11 ¾ inches
Height:     203 mm / 8 inches
Bore:     35.7 mm / 1 7/16 inches
Stroke:     40 mm / 1 5/8 inches
Flywheel diameter:     157 mm / 6 3/16 inches
Large pulley (round belt) diameter:     112 mm / 4 7/16 inches
Small pulley (flat belt) diameter:     51 mm / 2 inches
Weight:     12.9 kg / 28.4 lbs
Materials -
Frame (including base):     aluminium
Cylinder:     cast iron
Piston:     cast iron
Crosshead:     cast iron
Connecting rod:     bronze
Big end:     cast iron
Crankshaft:     steel
Main bearings:     bronze
Flywheel:     steel
Large pulley:     brass
Small pulley:     aluminium
Bushes and collars: bronze and cast iron
Fixings:     stainless steel
The plinth is made from solid oak with commercially-bought steel and rubber feet.
gary
Re: Uniflow Engine
« Reply #1 on: July 15, 2021, 02:29:45 AM »
Very well done Gary!
Re: Uniflow Engine
« Reply #2 on: July 15, 2021, 05:44:31 AM »
Very cool and unique engine, Gary!
Re: Uniflow Engine
« Reply #3 on: October 23, 2021, 11:52:59 PM »
Thank you Chris and Kim!
Offline MJM460
Re: Uniflow Engine
« Reply #4 on: October 24, 2021, 02:27:18 AM »
Hi Gary Great to see the finished project in the showcase.
Interesting strobe effects on the flywheel as speed varies.
With all those bolts in the flywheel, it would be a great platform for some balancing experiments!
Well done on the artistic adaption of the original design.
Re: Uniflow Engine
« Reply #5 on: October 24, 2021, 11:08:36 AM »
Hi MJM.
Thanks for your kind words and for all your advice and support with this project and others.
 :ThumbsUp:
gary
Offline Bearcar1
  • Chicagoland Area, USA
Re: Uniflow Engine
« Reply #6 on: October 24, 2021, 01:04:48 PM »
SWEET!!! Very nicely done Gary ...  :DrinkPint:
BC1
Re: Uniflow Engine
« Reply #7 on: October 24, 2021, 01:51:52 PM »
Many thanks Jim!
Offline propforward
  • MN, USA
Re: Uniflow Engine
« Reply #8 on: October 24, 2021, 11:38:01 PM »
Superb Gary. Lovely showcase of that engine.
Forging ahead regardless.
Re: Uniflow Engine
« Reply #9 on: October 26, 2021, 12:19:16 AM »
Super runner nice job Gary……
‘Don
Offline Hugh Currin
  • Box Elder, SD, USA
    • www.currin.us
Re: Uniflow Engine
« Reply #10 on: October 26, 2021, 01:16:05 AM »
Gary:
Very nice engine, great job. It has a bit of steam-punk flavor which I really like.
Thanks.
Hugh
Re: Uniflow Engine
« Reply #11 on: October 26, 2021, 06:37:39 AM »
Stuart, Don and Hugh - thank you very much.
@Hugh - yes, I do like to punk the steam from time to time!  ;)
