Author Topic: Now Seal starter motor  (Read 8368 times)
Offline Charles Lamont
Re: Now Seal starter motor
« Reply #75 on: July 20, 2021, 10:48:10 PM »
Yes please. Longer the better!
Offline Allen Smithee
  • Mordor, Middle Earth
« Reply #76 on: July 21, 2021, 12:08:22 AM »
OK. It's on my to-do list.
AS
« Reply #77 on: July 21, 2021, 04:00:19 AM »
Excellent.  I will be following too.
Offline gadabout
« Reply #78 on: July 21, 2021, 08:56:42 AM »
Some more pics of the starter fitted to the Seal 15cc
Mark
« Reply #79 on: July 21, 2021, 12:59:28 PM »
Hello Mark,
That is a neat and nicely made starter motor installation.  :ThumbsUp: :ThumbsUp:
« Reply #80 on: July 21, 2021, 04:53:17 PM »
That's some neat packaging  :praise2:  :praise2:
Offline Laurentic
« Reply #81 on: July 21, 2021, 05:57:06 PM »
I like that Mark, looks really good, nice job done there, good on you
Offline gadabout
« Reply #82 on: July 22, 2021, 10:42:44 AM »
Thanks for the kind words! Really must JB Weld that casting flaw in the cylinder water jacket, didn’t realise how bad it looks!
Regards
Mark
Offline gadabout
« Reply #83 on: July 22, 2021, 10:46:19 AM »
When I get time I will take a pic or two of the starter parts in an exploded view if anyone is interested
Mark
« Reply #84 on: July 22, 2021, 11:59:01 AM »
This is the starter gearbox I am intending for the Seagull. It will drive on the timing end of the crankshaft. The pink output gear is fixed to the black cup that carries the red outer race of the sprag clutch. The inner race is keyed to the output shaft, and these are the only bits that revolve when the engine is running
« Last Edit: July 22, 2021, 12:05:25 PM by Charles Lamont »
Offline gadabout
« Reply #85 on: July 23, 2021, 12:59:15 AM »
Charles,
That looks nice! I was wondering how you had it set up, might have to revisit mine to see if I can fit a one way bearing to the flywheel.
Regards
Mark
Offline gadabout
« Reply #86 on: August 07, 2021, 12:54:19 PM »
Trying out the starter
<a href="https://www.youtube.com/watch?v=LWBAeiFZSUY" target="_blank">http://www.youtube.com/watch?v=LWBAeiFZSUY</a>
Mark
« Reply #87 on: August 07, 2021, 03:18:43 PM »
Hello Mark,
I like it.  :ThumbsUp: :ThumbsUp: :ThumbsUp: Your starter motor does the job very well. No fuss no drama.
« Reply #88 on: August 07, 2021, 08:44:57 PM »
I can only agree with Mike - it works a treat  :ThumbsUp:
Offline gadabout
« Reply #89 on: August 08, 2021, 10:32:55 AM »
Hi Mike, Admiral,
Yes I’m calling it a success , now to tidy it all up as it looks very messy in the vid. Work out a few details and get the boat finished , eager to see how/if it starts in the water. Going to use quite a small prop as I’m not after speed, think that should make it easier to start in the water . Also it’s driving a lay shaft under the motor that is geared down too.
Thanks
Mark
